Author Topic: How to print the model date in a script?  (Read 4350 times)
michielper
« on: January 31, 2022, 08:44:16 pm »
I would like to have my script print the last modification date/time of the current EA model. I know how to do this with the DocumentGenerator but I am not using that in this particular script.
Preferably, I would like to be able to access the modification date/time of the running script itself, would that be possible?
Re: How to print the model date in a script?
« Reply #1 on: January 31, 2022, 08:49:29 pm »
Probably the easiest way is to run a SQL over t_object and get the most recent modification date. Depends on the type of SQL you are using to obtain the first record only.
« Reply #2 on: January 31, 2022, 09:11:08 pm »
The scripts themselves can be found in t_script, but the don't store a modification date, so not really possible.
As for the last modified date on the model, there are modifiedDates in both t_object as t_diagram.
I guess if you take the most recent of the two you'll be close to the last modified date.
It's not 100% accurate as I can still change other thing (connectors, attributes, tests, etc...) without affecting any of these modification dates, but it is probably close enough.
In SQL server that query could be
select top (1) m.ModifiedDate
from
(select o.modifiedDate from t_object o
union
select d.ModifiedDate from t_diagram d) m
order by m.ModifiedDate desc
