Author Topic: Where do I set EAworker diagram generation options?  (Read 74850 times)
wivel
  • Driven by Models
« on: March 25, 2022, 11:20:10 pm »
Hi.
Does anyone know how and where to set the EAWorker options for generating diagram images?
I have configured my local EA to not use bold element names and to show both Name and alias on elements. It works fine when I work in EA, but it seems to be overwritten by the EA Default options by the EAWorker, when it generates images for WebEA.
What happens is:
- I save a diagram in EA
- When I look at it in WebEA, it shows the diagram image with the same options as mentioned above.
- After 5 to 30 seconds, the diagram image in WebEA changes back to using bold element names an only showing Alias or Name on elements.
It seems to me that that change happens when the EAWorker kicks in, and so, I would like to know how to change the EAWorker options?
I have tried logging in on my own machine with the EAWorker User ID and Password, but that, of course, shows my own settings.
Do I have to start EA on the same machine as the EAWorker runs and change the settings there or is there a more clever way of doing it?
Henrik
Modesto Vega
Re: Where do I set EAworker diagram generation options?
« Reply #1 on: March 26, 2022, 01:48:04 am »
Interesting, the behaviour you are describing is different from the one we see.
What happens is:
We don't see this behaviour, saving a diagram in EA does not result on a diagram appearing in WebEA.
What type of account do you use for the EAWorker User ID and Password? An Active Directory account?
Do you use model secutiry? We are having some difficulty configuring the EAWorker.
In a reply to another post, https://sparxsystems.com/forums/smf/index.php/topic,46274.0.html, Drakos suggested that to install a custom MDG for the EAWorker to use, you need to install EA on the machine hosting PCS. If this is the only solution, it is INMO a design flaw.
INMO if an MDG has been deployed as part of the model, it should be deployed to PCS and we available for WebEA.
wivel
  • Driven by Models
« Reply #2 on: March 28, 2022, 09:01:28 pm »
Can see that my question can be misunderstood, so to clarify.
The saved diagrams do not appear in the webbrowser in WebEA untill I refresh the page (CTRL+R, since I am on Windows at the moment). After the first refresh, the diagram looks at it does in EA, but after repeated browser refreshes in WebEA, it changes to show the diagram with default options, in my case, old element names and only showing the element Alias and not the element name.
We are using model security, and the EAWorker user is a regular EA User and not an Active Directory account.
I have read the post you mention regarding the MDG, nd it seems to be a variation of the theme, i.e. you must have EA installed on the PCS machine to make changes to defaut behaviour and to instale MDG's for WebEA to acknowledge.
Henrik
Modesto Vega
« Reply #3 on: March 29, 2022, 03:12:04 am »
Thank you Henrik.
Are you using HTTPS? The reason for the question is that we are seeing the following error when we try to use a regular EA User.
2022-03-25 12:11:51 [WARNING]: ERROR:  Pro Cloud Server: The http connection reported the following error: 12014
2022-03-25 12:11:51 [WARNING]: ERROR:  Pro Cloud Server: The password was not allowed
We have an ongoing support case open but I think it is going to get a while to get a resolution.
Edit: I forgot to ask, what rights/permissions have you given to the standard EA User?
« Last Edit: March 29, 2022, 04:06:57 am by Modesto Vega »
wivel
  • Driven by Models
« Reply #4 on: March 29, 2022, 11:41:11 am »
You are welcome.
Since the model is only visible on the companys intranet, we are not using HTTPS at the moment.
As for the rights/permissions, I assume you are referring the the EAWorker user? It has all user permissions except for 'Configure Model Add-Ins', 'Configure External Data Sources' and 'Visibility Level Admin'.
Henrik
wivel
  • Driven by Models
« Reply #5 on: March 30, 2022, 09:03:10 pm »
It just occurred to me, that, in my mind, The EAWorker's job is to generate diagram images only when it is not present in WebEA, but in my case, it seems that all diagrams are being regenerated.
Is that how it is supposed to work, or is it a bug?
Henrik
Modesto Vega
« Reply #6 on: March 30, 2022, 09:21:03 pm »
My understanding is that the role of the worker is generate diagram images for each diagram that has been modified using the desktop tool, and keep those images up to date. Based on the behaviour we have seen so far, it sits there "listening" and every few seconds or minutes springs into action an generates/regenerates diagram.
There are a couple of things I don't understand.
1) The worker as a process is started and terminated by PCS. So I do not understand why it cannot always run using the account used to run the PCS service. Having to use a valid model user if model security is enabled makes no sense to me, but maybe there is a good reason for this.
2) I do not understand why PCS does not generate an image each time the diagram is saved using the desktop tool and just leave the image untouched.
Lastly I have noticed some registry keys on the server related to the worker, I found them under HKEY_CURRENT_USER\SOFTWARE\Sparx Systems\SQLBridge. They appear to be user specific and this puzzles me because I would expect them to apply to the whole server.
One of those keys is the path to a project 'start' file, EAExample.eap. I wonder is replacing the project starter or changing any other settings will affect the behaviour if WebEA.
wivel
  • Driven by Models
« Reply #7 on: March 30, 2022, 11:48:59 pm »
That is also how I see it now, but I was under the impression that the EAWorker only generated missing diagram images and left already generated images alone. Generating all diagram images is an ussue for us, since we have a large repsoitory, where different pojects/groups are using different diagram options. When using EAWorker, these options will be ignored since the diagram images are being regenerated using the options stored on the PCS Server. In our case the default options, since we have not installed EA there.
The EAWorker can be considered being a headless EA instance running as a service on the PCS Server, which is why it needs an EA user account to work. That also explains why you need to install a local EA instance on the PCS server and log on as the EAWorker user in order to e.g. install MDG's and change diagram options.
It does, if you ask it to do so in EA (Configure -> Options -> Cloud -> Data Cache), but it works only if you physically save the diagrams in EA. When copy/pasting packages or importing packages containing diagrams, images will not be generated, resulting in the 'Diagram Image Not Found' error in WebEA. That is the issue we tried to solve using the EAWorker.
You can configure the EAWorker using the PCS config tool, and you configure it per PCS connection. The 'start' file is not an option there, so I assume it is there since the EAWorker is running as a headless EA instance and thus need a repository. I don thing it uses it for other reasons than to be able to run.
You could argue, that using the EAWorker you can ensure that all of you diagrams will adhere to the same standards. The downside is that the diagram images shown in WebEA might not look like the coresponding diagrams in EA, which is the issue at us.
We have decided not to use the EAWorker. If you copy/paste packages or import, it is your responsibility to manually generate the diagram images. (Configure -> Options -> Cloud -> Data Cache -> Create -> Only missing Items)
I would like to see an option, where the EA Worker only generated missing diagrams, but it still doenst solve the issue with different diagram options for different groups/projects.
Henrik
Modesto Vega
« Reply #8 on: March 31, 2022, 01:51:57 am »
Thank you Henrik, really much appreciated. You have just provided a solution to the last wrinkle we had in our WebEA deployment. We will not use the EAWorker and make each user responsible for generating the diagram images used by WebEA.
wivel
  • Driven by Models
« Reply #9 on: March 31, 2022, 02:02:18 am »
You are welcome. Glad that our experiences can be of use for others as well.
One word of caution, though. If you choose to regenerate all images and/or linked documents, they wil be generated using the local Diagram settings of the user regenerating them.
Henrik
« Reply #10 on: March 31, 2022, 04:06:11 am »
IIRC there is also a settings that creates the images automatically when saving a diagram, so no need for a user to take manual action.
wivel
  • Driven by Models
« Reply #11 on: March 31, 2022, 06:55:15 pm »
Hi Geert
We have enablet these settings, and creating diagram images when saving a diagram in EA works fine. There is a corner case, as I have mentioned earlier in this post, that if you copy/paste or import packages containing diagrams into the model repsoitory, diagram images will not be created, for those diagrams. It was that issue we tried to get around by using EAWorker.
I will create an enhancement request, to have diagram images created also when copy/pasting and importing packages containing diagrams. That would solve it for us.
Henrik
Modesto Vega
« Reply #12 on: March 31, 2022, 07:10:31 pm »
Just for clarity the setting we are all referring to is Configure -> Options -> Cloud -> Data Cache -> Auto create Diagram Image and Image Map (each time a Diagram is saved) with the checkbox ticked.
Henrik - You have my vote on the enhancement.
Modesto Vega
« Reply #13 on: April 02, 2022, 03:49:05 am »
A significant part of the issue here is Sparx EA idiosyncratic way of identifying that a diagram has changed. It is actually possible to make changes to diagram elements without Sparx EA detecting that the diagram has changed - i.e., putting an '*' on the left hand-side of the diagram name. For example, I have the notes/description of various elements in a diagram and, as long as I do not change the diagram layout, Sparx EA does not detect a change; as result I cannot save the diagram and regenerate the cached diagram image.
The worker could play a critical in solving this.
« Reply #14 on: April 02, 2022, 01:25:33 pm »
A significant part of the issue here is Sparx EA's idiosyncratic way of identifying that a diagram has changed. It is actually possible to make changes to diagram elements without Sparx EA detecting that the diagram has changed - i.e., putting an '*' on the left-hand side of the diagram name. For example, I have the notes/description of various elements in a diagram and, as long as I do not change the diagram layout, Sparx EA does not detect a change; as result, I cannot save the diagram and regenerate the cached diagram image.
Modesto,
That's because you are modelling, not diagraming.  If the diagram layout hasn't changed, then the diagram hasn't changed.  It may be a moot point that if you change the name of something that is visible on a diagram that the diagram has changed (I would expect so), However, if there is no visible change then the diagram hasn't changed, in my view; so it's not TOO idiosyncratic.
