Author Topic: Migration from EA15 to EA16; What do we lose?  (Read 21341 times)
Nigel_Simpson
« on: May 04, 2022, 03:16:36 am »
Does anyone know what things in EA15 are no longer supported in EA16 and what manual conversion activity is required to upgrade? Specifically, I'm concerned that my existing VBScript scripts might not be supported and that the SQL queries I have created on a .eapx file might need rewriting for SQLite database. Is there anything else I might need to rewrite or change?
Re: Migration from EA15 to EA16; What do we lose?
« Reply #1 on: May 04, 2022, 06:41:14 am »
Probably not. Sparx is pretty good in keeping their versions backwards compatible.
wivel
  • Driven by Models
« Reply #2 on: May 04, 2022, 07:13:15 am »
Hi
Im with Geert on this one. I haven’t run into anything yet.
Henrik
Nigel_Simpson
« Reply #3 on: May 04, 2022, 06:46:15 pm »
OK, I have upgraded to EA16 and immediately many of my SQL queries (searches, fragments) do not work, as I suspected. Examples so far are 'wrong number of arguments to instr', 'no such function cstr', 'no such function mid'. Everyone should be aware that there will be possibly a lot of manual migration work after an upgrade from eapx to qea local file.
Modesto Vega
« Reply #4 on: May 04, 2022, 06:56:31 pm »
Are you using a proper database as the repository or have you moved/upgraded from eapx to qeapx files?
Nigel_Simpson
« Reply #5 on: May 04, 2022, 07:21:56 pm »
I moved an eapx file to a qea file. No proper database involved.
Modesto Vega
« Reply #6 on: May 04, 2022, 07:42:45 pm »
You are using different database engines eap/eapx is essentially an Access database and qeapx are SQL Lite. This is why your SQL statements are broken.
Sparx is good with backwards compatibility but that does not apply and has never applied to SQL queries.
Nigel_Simpson
« Reply #7 on: May 04, 2022, 07:56:32 pm »
Thank you for your input. My original question asked whether the change from eapx to sqlite would require manual actions from me. I now know it does. Others may wish to know too.
wivel
  • Driven by Models
« Reply #8 on: May 04, 2022, 11:03:33 pm »
Hi
Yep, you are right. Did some more testing and my Jet/eapx custom SQL needs to be rewritten on SQLite/Qeax models. My custom SQL in MSSQL models ported to QEAX seems to work directly without a rewrite.
Henrik
« Reply #9 on: May 04, 2022, 11:20:05 pm »
Sure, but you did more then upgrade.
You use database specific syntax in a query, then moved to a different database, and you are now surprised the other database complains about your syntax.
If I move to Oracle from SQL Server, lots of my queries will stop working as well. No need to upgrade to see that.
Nigel_Simpson
« Reply #10 on: May 05, 2022, 12:13:16 am »
No, I didn't move to a different database - the upgrade itself did that without my asking. I'm not complaining and I'm not surprised. I only asked whether there was manual work needed as a result of the upgrade, which there is.
« Last Edit: May 05, 2022, 12:16:20 am by Nigel_Simpson »
Modesto Vega
« Reply #11 on: May 05, 2022, 01:04:13 am »
I think you are hiding behind the semantical ambiguities of Sparxian. Technically, what Nigel and Henrik have done is a migration (to another RDBMS) and I would not expect Access SQL to work on SQL Lite or SQL server. Having said this, if Sparx Systems is calling what Nigel and Henrik did an upgrade, instead of a migration, I am afraid they are sending the wrong signal.
P.S.: I would expect to have to change all custom SQL if I were migrating, this is why I recommend to use a proper database, specifically SQL Server or PostgreSQL and stick with it.
« Reply #12 on: May 05, 2022, 04:22:34 am »
Wow, how did it "upgrade" automatically? I can still use my .eap(x) files without them being migrated to an SQLite.
I would be really annoyed if EA started to migrate my models to another technology without asking.
To be fair, you did ask if there was anything else besides the SQL you needed to rewrite. I responded to that question.
« Reply #13 on: May 05, 2022, 09:22:52 am »
The 64 bit edition of Enterprise Architect does not support '.eapx' model files.
You can migrate this model to a compatible format now using this upgrade too. To proceed,
select a suitable format from the supported list below.
Note you existing model will not be affected  by this process and will remain available in its
current location.
That's the text on the dialog that is shown if you attempt to open an eapx file with EA 16 64 bit. (Along with additional explanatory text describing each of the formats it will offer.)
It's described as both a migrate and an upgrade, but other than that it's pretty clear about what is going on. I struggle to see any way you can describe this as "I didn't move to a different database - the upgrade itself did that without my asking."
Nigel_Simpson
« Reply #14 on: May 05, 2022, 06:09:37 pm »
current location.
I only meant that I chose to upgrade to EA16 64-bit and so I had no choice but to upgrade/migrate/move/whatever to a .qea file. I'm not complaining about it, only trying to point out to others that there may be some (considerable in my case) further activity involved in the process. I don't have access to any other 'proper' database because my client won't allow it.
