Author Topic: EA Clone doubt  (Read 3472 times)
emiliano.davila
EA Clone doubt
« on: June 14, 2022, 12:53:55 am »
I have a doubt regarding the cloning of elements in EA, I am developing an addin that works with it and I need to identify from the original element which elements are clones, so far I can verify that they are elements related to this by "trace" and have a different version to the original element.
Is there any other way to identify clone elements in EA? in the t_objects table the 2 elements are identical, is there any other way to verify this? either by api or by database?
Re: EA Clone doubt
« Reply #1 on: June 14, 2022, 01:01:17 am »
Which mechanism do you use to create the clones?
Are you using the time aware modelling stuff (Clone element as new version)?
In that case I think you'll need to use the trace as you discovered.
