Author Topic: Cannot enable Model based Addin on model with security enabled (EA15.2)  (Read 20114 times)
satrman
Hi all,
having model with model based addin (java script) and there is no problem to enable it in local EAPX file without security enabled.
However if I enable security and assign group persmission "Configure Model Add-Ins" to User group I am in, I can assign a user group (tried both with/without "Configure Model Add-Ins" permission) and I can set disabled/enabled/optional + load on startup, however it does not load the Addin.
If I later disable "Configure Model Add-Ins" permission from group I am in (should let me turn on addin with "optional" setting at user level) it does not help either.
(Note: my key is to use it at a corporate level (have corporate license) in large MS SQL repository - however the issue is on both - security enabled EAPX and MS SQL as well)
I have figured out, that this setting goes to t_xrefsystem, however cannot move on...
Anyone can help me with this struggle, please?
Thanx in advance
Miloš
satrman
Somehow fixed it - recommended steps:
- create security GROUP A with Configure Model Add In
- create security GROUP B (no special rights needed)
- assign yourself to both groups
- in Manage-Addin assign your addin to GROUP B, set "Optional" and leave Load on Startup Blank
- remove yoursel from GROUP A
- in Manage-Addin check Load on startup
This view could be helpfull:
SELECT t_xrefsystem.Type
, t_xrefsystem.Visibility
, t_xrefsystem.Namespace
, t_xrefsystem.Requirement
, t_xrefsystem.[Constraint]
, t_xrefsystem.Behavior
, t_xrefsystem.Partition
, t_xrefsystem.Description
, t_secuser.UserLogin
, t_secgroup.GroupName
, t_xrefsystem.Client
, t_xrefsystem.Supplier
, t_object.Name
, t_xrefsystem.Link
FROM ((t_xrefsystem
LEFT JOIN t_secuser ON t_xrefsystem.Client = t_secuser.UserID)
LEFT JOIN t_secgroup ON t_xrefsystem.Client = t_secgroup.GroupID)
LEFT JOIN t_object ON t_xrefsystem.Supplier = t_object.ea_guid
Where
t_xrefsystem.Type in ('UserSettings', 'GroupSettings')
order by
,t_xrefsystem.Type
,t_xrefsystem.Client
shimon
Thanks for posting the solution. I got stuck on the same issue.
I didn't try it yet on the SQL based repository, but on a local file after enabling security, the problem was solved without removing myself from GroupA.
Sincerely,
Shimon
