Author Topic: Cannot insert duplicate key in object 'dbo.t_seclocks'  (Read 3237 times)
nilspc
« on: September 13, 2022, 10:20:22 pm »
We get the following error in the Pro Cloud Server log
2022-09-13 14:13:37 [WARNING]: Microsoft OLE DB Provider for SQL Server [-2147217873]
2022-09-13 14:13:37 [WARNING]: Violation of PRIMARY KEY constraint 'pk_seclocks'. Cannot insert duplicate key in object 'dbo.t_seclocks'. The duplicate key value is ({87EC09A9-CD9B-42df-BFCB-5912EFF01FFB})
Does anyone know why?
Everything seems to work fine
/Nils
steverumsby
Re: Cannot insert duplicate key in object 'dbo.t_seclocks'
« Reply #1 on: September 14, 2022, 07:08:26 pm »
I am getting the same thing. I have reported it to Sparx but they have no solution yet. We have had a few back and forth emails trying to figure it out. All they can say so far is that there's no model corruption going on so it is safe to ignore the error.
I suggest you report it to Sparx so they know it isn't just me that has this problem!
Steve.
nilspc
« Reply #2 on: September 15, 2022, 08:33:06 pm »
Thanks, I've have reported it to Sparx support
But i discovered a (one) way to reproduce the problem.
1.   Set a group lock on a diagram (a group your user is a member of)
2.   Open the diagram
3.   Change something in the diagram
4.   Save the diagram and the error message appears in the system out and the pro cloud server logs
/Nils
steverumsby
« Reply #3 on: September 20, 2022, 11:37:00 pm »
I had figured out that it was something to do with diagram locks, and let Sparx know about that, but I haven't found a way to reliably reproduce it for me. When ever I try, sometimes it happens, sometimes it doesn't. Sometimes I can change one thing and that's fine but changing (or adding) a second triggers the message. Sometimes it is the third. It is very frustrating!
If you can trigger it reliably then for sure that will help them track it down. 🤞
Steve.
DaisyNJ
« Reply #4 on: August 14, 2025, 10:00:49 pm »
Was a resolution ever received from Sparx Support for this? We are experiencing the same error.
steverumsby
« Reply #5 on: August 29, 2025, 08:43:17 pm »
No, apart from acknowledging that the problem exists I've heard nothing else. It isn't the only problem I've reported that they don't seem to be making progress on fixing :(
At least this one doesn't appear to cause an issue and can safely be ignored. At least, I have been ignoring it for years without incident. Annoying though...
