Author Topic: RunModelSearch  (Read 8420 times)
OpenIT Solutions
RunModelSearch
« on: February 13, 2013, 03:56:19 am »
Is it possible to use RunModelSearch from the automation interface to run a model search and send the result to a file ?
It looks from the docs that output will always go to the Model Search screen ?
Jon.
Re: RunModelSearch
« Reply #1 on: February 13, 2013, 04:04:01 am »
Well, it has a ShowInEA: Boolean which you can obviously turn off. The output then goes to the NULL device. Seems to make a lot of sense.
I can't think of a hack to get the results since the model search understand tags like #Branch#. That way you can't even try to get the underlying SQL and perform a Repository.SQLquery.
OpenIT Solutions
Re: RunModelSearch
« Reply #2 on: February 13, 2013, 04:58:59 am »
Can you not select a package using the automation interface - that way #branch# should work - it feels like its half way there - it would be a useful feature....
Re: RunModelSearch
« Reply #3 on: February 19, 2013, 11:50:42 pm »
I have a case where I get the custom SQL seaches defined by the user and use their sql definitions in a call to Repository.SQLQuery()
They are defined in %AppData%\Sparx Systems\EA\Search Data\EA_Search.xml
But that doesn't work for standard searches.
Re: RunModelSearch
« Reply #4 on: February 20, 2013, 12:10:03 am »
No. You only can select elements in a diagram (via SelectedObjects). However, being able to select an element in the browser would be a nice feature.
[edit] Geert is right. I looked for the method (since not having used it for ages) and did not find it instantly.
« Last Edit: February 20, 2013, 02:43:17 am by qwerty »
Re: RunModelSearch
« Reply #5 on: February 20, 2013, 12:23:57 am »
Yes you can.
Repository.ShowInProjectView()
Ian Mitchell
Re: RunModelSearch
« Reply #6 on: May 25, 2013, 09:51:10 pm »
I think there may be a bit of confusion here.
There are two RunModelSearch methods: one in Repository, one in ProjectInterface.
ProjectInterface.RunModelSearch one has the one which just runs the search and allows for the showInEA option. Which seems to work just fine, but doesn't return the results.
Repository.RunModelSearch also runs, but the API documentation says it returns a string with the results.
Has anyone made this work? I can run it, and the search runs OK (but it also displays the results in the EA User Interface, which I don't want) but I can't get it to return any results.
In order to test it, i'm not passing any search criteria:
currentEARepository.RunModelSearch(QueryName:=strReportName,
                                                   SearchTerm:="",
                                                   SearchOptions:="",
                                                   SearchData:=strXML)
..but strXML is empty. The strReportName is OK, because the seach runs.
Is this a bug, or am I doing in wrong?
www.eaDocX.com
www.theartfulmodeller.com
Re: RunModelSearch
« Reply #7 on: May 27, 2013, 09:12:22 am »
Read the docs for Repository.RunModelSearch. That last parameter is an input of results to append to the search.
You could try using Repository.GetElementsByQuery()
Re: RunModelSearch
« Reply #8 on: May 27, 2013, 04:49:38 pm »
True, I completely forgot about that one. :-[
That works fine, for both standard as custom SQL searches, but only if those searches return contain guid's of EA.Elements.
If you have other types of elements as the result of your search you'll have to use Repository.SQLQuery().
