Author Topic: Unicode in ModelView SQL (XML-escape)  (Read 1937 times)
Hurra
    • Find me at LinkedIn!
« on: November 07, 2022, 09:21:43 pm »
Hello!
I have a problem similar to:
https://www.sparxsystems.com/forums/smf/index.php/topic,43909.0.html
-> My text in Element.Note is XML-escaped and therefore replace characters with HTML-number (?) like å
But I have my query in a ModelView, and therefore no template to add custom field.
I find my element(s) with a query and want to print Element.Note.
I want the Element.Note column to show formatted text. I tried a lot of different stuff.
Element.Note AS [Note-Formatted]
Element.Note AS '[Note-Formatted]'
Element.Note AS [Note.Formatted]
Element.Note AS '[Note.Formatted]'
Element.Note-Formatted AS 'Notes'
Element.[Note-Formatted] AS 'Notes'
Element.[Note.Formatted] AS 'Notes'
I'm getting lost 😇
NOTE: this is a local QEAX-file.
I think I solved this one time somewhere, but can find how I solved it, or found the source to that solution. With this thread I'll know where to go!
Thank you for your time!
always learning!
Re: Unicode in ModelView SQL (XML-escape)
« Reply #1 on: November 07, 2022, 10:17:51 pm »
I don't think there's a solution for this in EA currently.
I don't see any way to show the notes, except by tricking EA to hide the fact that a column actually contains a notes (formatted) text.
Therefore I assume that EA is not equiped to show formatted notes in modelviews.
The best thing to do is probably send in a feature request.
Hurra
« Reply #2 on: November 09, 2022, 07:40:50 pm »
OK!
Thank you Geert!
always learning!
