Author Topic: V16.1 Diagram legend connectors colours not visible  (Read 9131 times)
Guillaume
    • www.umlchannel.com
« on: November 17, 2022, 11:34:25 pm »
I opened a diagram with a diagram legend showing colours for different types of connectors.
With EA16.1 (build 1621), the legend only shows the values but no coloured lines. It works fine for elements or with a previous build of EA.
Guillaume
Re: V16.1 Diagram legend connectors colours not visible
« Reply #1 on: November 18, 2022, 12:04:01 am »
Nice catch, another regression it looks like.
BobM
« Reply #2 on: November 18, 2022, 08:29:23 pm »
The same issue is present for v16.0
Older diagrams that have legends based on tags did not display the default tag value
Guillaume
« Reply #3 on: November 18, 2022, 09:06:26 pm »
This bug has been reported to Sparx.
Guillaume
Modesto Vega
« Reply #4 on: November 18, 2022, 09:59:24 pm »
Need to research this, on 16.0 we have successfully used legends to change colour of connectors based on tag values defined as part of an MDG. Having said this, the diagram was created with v15.
« Reply #5 on: November 18, 2022, 10:21:45 pm »
The connectors change color just fine. You simply can't see the color anymore on the legend.
Takeshi K
    • Sparx Systems Japan
« Reply #6 on: November 20, 2022, 08:49:24 pm »
Hello all,
You can see them by setting the following option to 'Enhanced -2':
Preference | Appearance | Renderer
The default 'Enhanced -1' has other problems in drawing, I do not recommend to use the default option.
(I reported another 'Enhanced -1' issue before but not fixed on 1621)
t-kouno
« Reply #7 on: November 20, 2022, 09:52:09 pm »
Hello all,
Confirmed, thanks. I didn't know about the Enhanced issues.
wivel
  • Driven by Models
« Reply #8 on: November 22, 2022, 12:10:13 am »
What Geert said, but drawing a line in a Legend should not be dependent on the renderer.
It works with 'Basic' too, BTW.
Henrik
Modesto Vega
« Reply #9 on: November 22, 2022, 02:10:39 am »
Well in v16.0 (build 1605) 64-bit with "Enhanced-2" as the preference, several weird and, thankfully, non-destructive things happen with the connectors. For example, if you select everything in a diagram (Ctrl-A), deselect some elements, and reposition the rest using Shift-Left or Shift-Right a number of connectors become invisible while the operation is taking place (and only become visible after they deselected).
Oddly this does not happen with Shift-Up or Shift-Down.
Haven't yet try 16.1.
Modesto Vega
« Reply #10 on: November 22, 2022, 03:55:13 am »
Same behaviour in 16.1.
« Reply #11 on: November 26, 2022, 12:44:56 am »
According to the release notes this should have been fixed in version 1622:https://sparxsystems.com/products/ea/history.html#1622
wivel
  • Driven by Models
« Reply #12 on: November 26, 2022, 03:03:44 am »
It is fixed. Just tested it since I had the same issue.
Henrik
