Author Topic: Stability of 1605  (Read 6481 times)
Re: Stability of 1605
« Reply #15 on: December 07, 2022, 11:51:52 am »
Problem must be a doozy, in use EA is not staying up for more than an hour.
I can say it doesn't matter whether I am accessing our DB (SQL Server) via PCS or directly.
Pretty close to the point where I will have to roll it back if I don't hear anything.
« Reply #16 on: December 08, 2022, 01:31:12 pm »
After 27 crash dumps I gave up on 16.0.
I was able to get build 1622 manually installed in the hope the problem would have been fixed.
But it only took a few minutes until crash 28 occurred.
I have been thinking the crashes only occurred when I was manipulating diagrams,
but I was disabused of this when it crashed as I edited an entity in the properties windows.
ah well
« Reply #17 on: December 08, 2022, 01:51:44 pm »
I haven't seen all of your stack dumps, but the ones I saw didn't provide anything useful.
Have you tried the 32 bit version? I don't think I've seen that many crashes in 16 and I was using the early development 16 64 bit version consistently for almost a year before it was released.
« Reply #18 on: December 09, 2022, 09:38:22 am »
Thanks.
Managed to get 16.1 1622 32 bit installed and its stable.
« Reply #19 on: December 09, 2022, 01:01:34 pm »
Thanks.
Managed to get 16.1 1622 32-bit installed, and it's stable.
Yes, we've found that also...
« Reply #20 on: December 09, 2022, 03:54:40 pm »
Thanks.
I'll quality that, down to one crash in an afternoon (and mini-dump dispatched)
« Reply #21 on: December 19, 2022, 08:59:17 am »
Update: I have now been able to send off mini dumps.
Apparently they show "nothing useful"
Amazingly I was able to (after a time) get the ability to run PrcMon and ProcExplorer and see the event log and have provided all these dumps to support.
I am now hoping to hear from them and find out what the issue is.
I do think it is related to working a lot in diagrams (memory leak or dangling pointer anyone?)
The 32 bit is relatively stable (i.e. not as stable as v15)
