Author Topic: Windows Srv 2012 - Task Schedule - COM permissions  (Read 5392 times)
Andreas1975
« on: June 10, 2013, 10:04:04 pm »
Hi.
I know there are several posts with similar topic, and I've spent weeks reading them, and try to get this to work.
I try to automate the generation of the html-report (using the java-api, since thats the language I can).
I kick it off using a bat-file, and that works excellent when going through the command prompt. However - Scheduling this as a Window Task (using same administrative user on Window Server 2012), I get error messages that very much seems to relate to COM-permissions that is described in several other posts.
I just cant figure out where on Windows Server 2012 I can configure this permission (if it is a COM-permissions issue)?
Anyone know, or can hint me in right direction?
thanks
/Andreas
Re: Windows Srv 2012 - Task Schedule - COM permiss
« Reply #1 on: June 11, 2013, 05:18:26 am »
You need a user to run EA.
Andreas1975
« Reply #2 on: June 11, 2013, 05:42:43 pm »
Yes, I have a user.
And with the same user the scripts goes excellent using the command-prompt, but not as a Scheduled Task (Wich is configured to use the same user).
I also tried another special user that I set all special OS permissions I could find ("act as part of operating system", "run as batch") etc... all thoose special permissions not even an Administrator has...
Still no success...
regards
Andrea
