Author Topic: Locked Element is EA 16.1 are still able to be updated.  (Read 6247 times)
pb17
« on: March 23, 2023, 08:49:13 pm »
Hello Everyone!
When trying to update and create new block diagrams in EA v16.1 build 1624, I´ve noticed that the locked elements can be traced to and from and have its properties changed. In version v15.1, this was not possible and when I tried to do the same a pop-up message appeared Stating "Warning: Connector cannot be created. Aggregation Element is locked or checked into version control".
I´ve been reading the release notes, but I´m failing to understand why this occurs. Has anyone encountered this?
Any help is appreciated.
Thank you in advance.
Re: Locked Element is EA 16.1 are still able to be updated.
« Reply #1 on: March 23, 2023, 09:13:25 pm »
There is an option somewhere that says something like "include locks on connectors".
IIRC that option changes the behavior with regards to locking and connectors.
I'm not sure if that will solve your poblem, but it is probably worth a try.
pb17
« Reply #2 on: April 03, 2023, 06:26:15 pm »
Thank you for the replay and support.
I´ve tried your suggestion and the problem remains.
I´ve reached out to Sparx Support.
Once again, thank you for the support  :).
