Author Topic: Accessing diagram frame of SysML diagrams  (Read 6582 times)
vrieg
« on: May 06, 2023, 01:36:36 am »
Hello all,
I would like to move a SysML diagram from one package to another using EA API.
To do so I need to disable the diagram frame, safe (refresh) the diagram and package upfront.
Is there a way how the diagram frame can be accessed? Unfortunately documentation is quite weak here.
Re: Accessing diagram frame of SysML diagrams
« Reply #1 on: May 06, 2023, 03:07:26 am »
I think it's a property of the diagram, so probably to be found in either Diagram.Pdata or Diagram.ExtendedStyle
The way I find out stuff like that is to use SQL Profiler. This tool records all database queries. So I turn it on, change whatever I'm investigating in EA, and then turn it off again.
Then by looking through the logs I find what exactly EA changed in the database.
« Reply #2 on: May 06, 2023, 06:03:33 am »
My way is a bit different. I create an XML dump of all tables from a (as unpopulated and small as possible) repo, make the changes and compare the 2nd dump via WinMerge. That shows exactly the changes.
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: May 08, 2023, 09:51:31 am »
Hello vrieg,
Diagram frames of SysML are just DiagramObjects of the parent packages or elements (e.g. Blocks).
So, removing the DiagramObject from the Diagram.DiagramObjects collection can disable the diagram frame.
t-kouno
vrieg
« Reply #4 on: May 08, 2023, 04:56:45 pm »
I am not sure how this should work. Can SQL Profiler can access local EA fies as eapx files?
Recording commands and transactions might be really beneficial.
Could you explain this a bit more?
This was working for me. The actual command was
EA.Diagram Diagram1 = currentlySelectedPackage.Diagrams.AddNew("DiagramName","");
                Diagram1.MetaType = "SysML1.4::BlockDefinition";
                Diagram1.Update();
                string currentstyleex = Diagram1.StyleEx;
                outputTab.WriteInfoMsg("current extended string" + currentstyleex);
                Diagram1.StyleEx = "SF=0;";
                Diagram1.Update();
                repository.SaveDiagram(Diagram1.DiagramID);
                repository.RefreshModelView(currentlySelectedPackage.PackageID);
                repository.RefreshOpenDiagrams(true);
                repository.ReloadDiagram(FunctionalArchitectureDefinitionDiagram.DiagramID);
« Last Edit: May 08, 2023, 05:06:31 pm by vrieg »
« Reply #5 on: May 08, 2023, 05:11:44 pm »
No, SQL Profiler is a MS SQL Server tool. There might be similar tools voor jet files as well, but I do all of my development on MS SQL, so I haven't really looked into that.
99% of my clients use SQL Server anyway as their backend.
You can install and use MS SQL Server Express completely for free, so if you have admin rights on your machine you can install and use it.
