Author Topic: Move elements in other ways than drag-and-drop?  (Read 13393 times)
miksko
« on: May 13, 2023, 12:09:30 am »
If you want to move, say, a use case from one package to another you can simply drag it to the other one.
But you may desire a more restricted way of moving things around --- particularly when it will affect a number of use cases -- in order to to limit the risk of dropping them in the wrong place.
I've come across other modeling tools which offer a wizard-like dialogue: Select the elements. Right-click and select the Move functionality. A dialog window opens, to let you select the destination by browsing a package tree.
Is there anything similar available in Sparx EA?
Re: Move elements in other ways than drag-and-drop?
« Reply #1 on: May 13, 2023, 12:14:40 am »
Yes, select source
- context menu | Copy / Paste | Cut
Select target
- context menu | Copy / Paste | Paste
BobM
« Reply #2 on: May 15, 2023, 04:13:40 pm »
right click on element -> insert related element
Currently known as bugged (only one filter block works at a time)
They will fix the filter issue in a future release
« Reply #3 on: May 15, 2023, 05:28:03 pm »
This is for showing elements on a diagram, not for moving them from one location to another.
miksko
« Reply #4 on: June 15, 2023, 04:26:13 pm »
Yes, select source
Select target
Thanks, Gert! And sorry for not getting back to you until now. I've tried this feature a number of times now, and it not only works well but also quickly.
I know that I once searched for a cut-and-paste functionality but was only able to find a copy-and-paste. I have probably figured out why: When I try to recollect and repeat the steps, I notice that the cut functionality disappears as soon as you select more than one element.
Mikael
Takeshi K
    • Sparx Systems Japan
« Reply #5 on: June 15, 2023, 04:59:53 pm »
For your information,
Simpler, select items in the Browser and Press Ctrl+X, and then select a target package in the Browser and press Ctrl+V.
t-kouno
« Reply #6 on: June 15, 2023, 05:19:08 pm »
So cut is available, but only if you use the keyboard shortcut Ctrl+X?
If it works, then it should be available in the context menu as well IMHO.
I would consider that a bug.
miksko
« Reply #7 on: July 04, 2023, 07:38:43 pm »
Ctrl+X works, as Takeshi writes and also when you select multiple elements. I've confirmed it.
The context menu option disappears though, which I will report.
Mikael
