Author Topic: Doubt with EA 16 cloning  (Read 2997 times)
emiliano.davila
« on: June 03, 2023, 12:28:14 am »
Hello everyone
I have a question regarding EA cloning.
 in version 15.2 when cloning as a new version I could manually choose the version of the item to clone.
But this behavior seems to have changed in version 16, where it is not possible to change this version, because the box is read-only.
Is this a desired behavior of EA? is it a bug? is there a setting that allows me to change it?
Note: the screenshots are with the Spanish EA, but I tried with the English versions and the behavior is repeated in 15.2 and 16.1.
Re: Doubt with EA 16 cloning
« Reply #1 on: June 03, 2023, 05:54:34 am »
That looks like you should report a bug. V16 has already some so this one will make friends easily.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: June 05, 2023, 09:15:27 am »
Hello Emiliano,
If you cloned the package as the version '1.0', it seems to work correctly.
I have not checked it on the version 15.2, but I think it is consistent (and maybe intended) behaviour if the package is cloned as version '1.0', all cloning elements should be the same version.
t-kouno
