Author Topic: Generate DDL encoding issue  (Read 3831 times)
stetou
« on: November 30, 2023, 04:12:24 am »
I'm using  EnterpriseArchitect (16.0.1605) with a DBMS repository
Connection / DBMS:  OLEDB - MS SQL Server
Database Schema Version: 1558
Whatever I set as code page in the Code Generation Options
https://sparxsystems.com/enterprise_architect_user_guide/16.0/modeling_domains/code_generation_options.html
When I generate DDL the generated fil is ANSI encoded.
If I want the files in UTF-8, what else should I change in the settings ?
