Author Topic: How to set-up mutiple EA repositories in one Pro Cloud Server  (Read 73017 times)
Sjaak62
« on: December 13, 2023, 09:28:28 pm »
I've been looking around, but cannot find how to create multiple EA repositories in one Pro Cloud Server. We're using the Pro Cloud Server to access it using the Sparx EA client, and want to have a separate repository for each functional team. Anyone who can give me a pointer to an instruction to accomplish this?
Re: How to set-up mutiple EA repositories in one Pro Cloud Server
« Reply #1 on: December 13, 2023, 09:47:11 pm »
I'm not sure where you are stuck. It's a matter of setting up a repository, and then linking it in the PCS manager just like you did with the first repo.
BobM
Sjaak62
« Reply #3 on: December 20, 2023, 11:47:01 pm »
Hi Geert and Bob,
I'm actually stuck at that I have one SQL Server based repository available using the PCS, and I want to add a second SQL Server based repository to the PCS. Is that just as simple as creating and initializing an additional repo database ( https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/settingupdatabasemodelfile.html ), and link the repository (step 5) as described inhttps://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/sscs_setup_overview.html
Reason why I cannot test this myself is that our private hosting provider does this setup for us, and I have to specify to them how to setup an additional repository.
Very much appreciated if one of you can positively confirm this.
Kind regards, Sjaak
BobM
« Reply #4 on: December 21, 2023, 01:56:42 am »
Hello sjaak,
Yes, it is that simple:
https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/upsizingtosqlserver.html
In the cloud server client they have to add a new database
https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/cloud_server_client.html
https://sparxsystems.com/enterprise_architect_user_guide/16.1/the_model_repository/cloud_server_client_add_sqlsvr.html
Forward the model name you want them to use
In Sparx client self you add use cloud connection with the same URL, port, but select the respective model name for the repository each team has to use
If you want to use RAS they need to enable procloud features (its not just WebEA)
If you want to access the models via WebEA as well you still need to add the model in the WebEA config as well
Sjaak62
« Reply #5 on: December 21, 2023, 05:27:38 pm »
Hi Bob, thank you very much, this really helps me to move this forward.
Kind regards, Sjaak
