Author Topic: Code Transform and Attribute Tags  (Read 7347 times)
hoylet
« on: February 05, 2024, 11:27:05 pm »
Hi
I have created a Transform based upon the Java code transform.
Is there a way of outputting all the tags applied to an attribute
for a specific tag I can do this :-
%WRAP_COMMENT(attTag:"protobuf field min value",genOptWrapComment,"","// protobuf field min value ")%
but I would like to output all tags
%WRAP_COMMENT(attTag:"*",genOptWrapComment,"","// ")%
Do I need to use list or some form of loop
Any suggestions would be most welcome
Re: Code Transform and Attribute Tags
« Reply #1 on: February 06, 2024, 01:34:30 pm »
Short answer. No.
Longer answer: Not within the templates themselves. You would need to call an add-in using EXEC_ADD_IN
I've done similar things in the past in some very complicated transforms using a model add-in.
« Last Edit: February 06, 2024, 01:37:14 pm by Eve »
hoylet
« Reply #2 on: February 06, 2024, 09:29:23 pm »
Thank you Eve I will look into that
