Author Topic: Adding a Tag to multiple elements at the same time  (Read 9517 times)
EAButNotForGames
« on: February 26, 2024, 08:39:36 pm »
I think I got a weird bug in version 16.1.
I cannot give multiple selected elements (of the same type) the same Tag.
Only one of the selected elements gets the new tag
Neither Add Tagged Value nor Ctrl+Shift+T works for that.
It is kinda tedious to give every element individually the tag.
And I can't be bothered to write a script for that.
Anyone got an Idea?
erchimney
Re: Adding a Tag to multiple elements at the same time
« Reply #1 on: February 26, 2024, 08:46:22 pm »
It seems that neither the "Add Tagged Value" option nor the shortcut Ctrl+Shift+T is working for this purpose. It can definitely be tedious to manually assign tags to each element individually, and writing a script may not be a feasible solution for you.
PDC
  • Systems Engineer
« Reply #2 on: February 26, 2024, 10:19:34 pm »
csv export/import would sort this out for you within 5 minutes.
Phil
billystoned
    • Drift Boss
« Reply #3 on: February 27, 2024, 12:07:59 pm »
On the 'Select Element Type' dialog, click on the 'Element Type' drop-down arrow and select the new element type from the list. Click on the OK button. The target element is transformed into the required type.
« Last Edit: February 27, 2024, 12:18:05 pm by billystoned »
« Reply #4 on: February 28, 2024, 08:26:26 pm »
I think I reported that as a bug more than a year ago.
It doesn't look like it has been fixed in the meantime.
