Author Topic: Creating a simple document generation template  (Read 5165 times)
Modesto Vega
« on: May 02, 2024, 08:45:25 pm »
This is not the 1st time I post about this, I am trying to create a simple document generation template without re-using the out-of-the-box Model Report which uses a/the Template selector. It seems that I have either forgotten how to do this, the functionality has changed or is broken, I am using 16.1.1628, and I am aware of the problem Geert reported and wrote about extensively when v16 was released.
I have a structure as follows:
Package 1
---Diagram 1
-----Package 1a
----------Diagram 1a
----------Element 1
----------Element 2
----------Element n
-----Package 2a
----------Diagram 2a
----------Element 10
----------Element 11
----------Element 1n
All I want is a document with the following sections and content:
Package 1 + Name [Section]
Package 1 Notes [Content]
Diagram 1 Image [Content]
Diagram 1 Notes [Content]
Package 1a + Name  [Section]
Package 1a Notes [Content]
Diagram 1a Image [Content]
Diagram 1a Notes [Content]
Element 1 Alias + Name + Notes
Element 2 Alias + Name + Notes
Element n Alias + Name + Notes
Package 2a + Name  [Section]
Package 2a Notes [Content]
Diagram 2a Image [Content]
Diagram 2a Notes [Content]
Element 10 Alias + Name + Notes
Element 11 Alias + Name + Notes
Element 1n Alias + Name + Notes
I cannot find a way of getting the items in red in the document no matter what I do. I am not even sure if the items in orange will appear. A template selector does it, but it is not my preferred approach, both a fragment (with SQL) or a script will do it but it will take to long.
What am I missing?
Re: Creating a simple document generation template
« Reply #1 on: May 02, 2024, 09:11:43 pm »
Hi Modesto,
How did you get the package nested under the diagram? I am assuming every 3 dashes indicates a level.  I thought you could only nest packages under packages.
There is no context menu to nest a package (or element) under a diagram.
Modesto Vega
« Reply #2 on: May 02, 2024, 09:26:58 pm »
Hi Paolo, that was a typo resulting from my slight irritation with Sparx a several other converging irritants, my apologies.
The structure looks like:
Package 1
---Diagram 1
---Package 1a
----------Element 1
----------Element 2
----------Element n
---Package 2a
Package 1 is a view sitting directly under the root.
« Reply #3 on: May 02, 2024, 09:49:19 pm »
I'm not sure why this would be so hard.
It should simply be
package>
diagram>
-- here the diagram stuff--
<diagram
element>
--here the element stuff--
<element
child packages>
<child packages
<package
And make sure you don't have any filters activated, and don't exclude any diagrams from the documentation.
Modesto Vega
« Reply #4 on: May 02, 2024, 10:14:15 pm »
Thanks Geert, I will try it again but that does not seem to be working. Of course, I could have made a silly mistake but cannot see it.
Modesto Vega
« Reply #5 on: May 03, 2024, 02:29:16 am »
Just an update on this, I had
package>
diagram>
element>
-- some element stuff (other than the one below)--
<element
<diagram
element>
<element
child packages>
<child packages
<package
As soon as, I removed that it started generating the right content.
