Author Topic: Relationships in Data Models  (Read 6479 times)
acohen1902
« on: June 03, 2024, 07:45:09 pm »
I am drawing a large data model as a result not all the entities are appearing on one screen which makes it very hard to draw. Is there a way of entering the target and related elements in a box rather than having to physically draw it in the class diagram? thanks
Re: Relationships in Data Models
« Reply #1 on: June 03, 2024, 07:55:23 pm »
use the relationship matrix, or a "working" diagram.
Modesto Vega
« Reply #2 on: June 04, 2024, 11:40:17 pm »
Is it possible to create a matrix showing just the following: the names and aliases of elements with a given stereotype that are present included in the same diagram as the matrix?
« Reply #3 on: June 04, 2024, 11:43:26 pm »
There is no such thing as "the same diagram as the matrix" as matrixes don't live on diagrams (or in the model).
But you can base your matrix contents on a query, so in theory that should be possible.
ea0522
« Reply #4 on: June 04, 2024, 11:54:52 pm »
You could also base your matrix on the elements available in a package.
Modesto Vega
« Reply #5 on: June 04, 2024, 11:57:26 pm »
It is possible to embed a matrix specification in a diagram, this what I was referring to.
« Reply #6 on: June 05, 2024, 12:13:47 am »
The problem with the matrix specifications is that you can only store the packages as source/target, no searches or queries.
Modesto Vega
« Reply #7 on: June 05, 2024, 02:31:10 am »
I think I am getting a bit lost here, on previous versions of Sparx EA it was possible to create a query driven matrix specifications. Have I missed something?
