Author Topic: DeleteLinkedDocument() has no effect  (Read 11928 times)
Jens Nötzold
« on: August 21, 2024, 01:25:08 am »
I didn't manage to get rid of an elements' linked document using EA.Element.DeleteLinkedDocument()
Can please somebody confirm that it's not an issue inbetween my left an right ear?
Jens
Jens Nötzold
Solved: DeleteLinkedDocument() has no effect
« Reply #1 on: August 22, 2024, 06:30:24 pm »
Adding a linked document via EA UI is not reflected to the COM-Object!
So prior trying to delete it, the reference to the element (COM-Object) needs to be reloaded first.
Jens
Re: Solved: DeleteLinkedDocument() has no effect
« Reply #2 on: August 22, 2024, 07:28:06 pm »
Jens
That is pretty much the standard way the API works.
Once you have an object in memory, it won't reflect any changed done in the GUI before you reload.
