Author Topic: Build 1703 „Find Command“ is missed  (Read 10708 times)
PeterHeintz
« on: September 24, 2024, 06:01:10 pm »
In build 1703 the „Find Command“ feature is missed (as I assume by mistake).
Best regards,
Peter Heintz
Re: Build 1703 „Find Command“ is missed
« Reply #1 on: September 25, 2024, 08:38:42 am »
As was the case before 17, it's limited to some visual styles.
PeterHeintz
« Reply #2 on: September 25, 2024, 04:09:47 pm »
Ok, I found it in Style Office 2016.
But I think you can admit this is quiet tricky.
Best regards,
Peter Heintz
« Reply #3 on: September 25, 2024, 04:21:31 pm »
The tricky part is that installing the new version also changed my preferred visual style to one where the find command is not available.
BobM
« Reply #4 on: September 25, 2024, 06:39:02 pm »
In office 2016 its on top,
in all other user interface versions its in the EA menu
« Reply #5 on: September 25, 2024, 07:41:09 pm »
That is almost (but not 100%) the same search box.
There is small differences in behavior and results between the two.
BobM
« Reply #6 on: September 25, 2024, 09:07:43 pm »
I'm sceptical sparx devs would code specific behavior for one single visual style, but I'll bite; Can you give examples of small differences where the box would be lacking functionality over the office 2016 visual style box (or vice versa)?
« Reply #7 on: September 25, 2024, 09:21:05 pm »
If you type in "trace" you get different results.
I don't know if that proves Sparx devs wrote different code, but the end result is that there are small differences.
PeterHeintz
« Reply #8 on: September 26, 2024, 05:24:28 pm »
Anyhow it is a "confuse the users" feature! ;D
Best regards,
Peter Heintz
Takeshi K
« Reply #9 on: September 27, 2024, 08:58:32 am »
Just for your information, the Ribbon (and the whole window management) is implemented using a third party library. We can know this by using some tools (e.g. Spy++).
So I would say that all the behaviour related to the Ribbon is defined outside the Sparx developers. You may say that they should change the behaviour, but I think they should concentrate on their own code and it is a nice solution to buy 'existing' features, even if they are not perfect for all of us.
You might also say that they should choose the 'perfect' library for everyone and every situation, not just at the time of selection, but in the future. I agree, if that is possible.
t-kouno
« Reply #10 on: September 27, 2024, 08:07:21 pm »
In Germany we say that "the fish stinks from its head". Looking back, most of the EAUI is caused by Mickeysoft's weirdness. Another saying: "The apple does not fall far from the tree trunk" probably applies in consequence.
« Last Edit: September 27, 2024, 08:43:49 pm by qwerty »
PeterHeintz
« Reply #11 on: September 27, 2024, 09:17:55 pm »
I do not say to what Sprax should concentrate anyway!
I just say it is confunsing!😉
Best regards,
Peter Heintz
