Author Topic: Information Flows Realized: Adding information item super slow  (Read 52632 times)
antoineatstariongroup
« on: September 25, 2024, 06:41:59 pm »
Hi !
I'm currently working on an Enteprise Architect model in SysML. The model is hosted into a VM (with PostgresSQL database) and can be accessed via the native connection.
Any update on the model is going smoothly, except the addition of information item when I can to put some 'Information Flows Realized' for some message on a Sequence Diagram.
When doing it, I notice a huge slows down of the system, where the pop-up dialog freezes and it really takes some time to be available again.
I'm facing this slow-down with the version 17.0 but also noticed it in previous version. Is it a specific thing that could be done on the server to resolve this issue ? (Doing the manipulation on a standard QEA file is completly fine).
Thanks !
Re: Information Flows Realized: Adding information item super slow
« Reply #1 on: September 25, 2024, 07:44:47 pm »
There are a few things you can try:
- Use Pro Cloud Server to connect instead of native connection
- Move the client closer to the database (and use Remote Desktop/Citrix to use it)
- Investigate on database level why this is taking so long. Sometimes adding an index can help a lot. In that case I would report the bug (and the solution) to Sparx so they can included it in the standard database DDL for PostgresSQL
« Reply #2 on: September 26, 2024, 09:54:09 pm »
Thanks Geert for you reply !
I tried to inspect logs related to insertion of those "Information Flows Realized" information, and it looks that the SQL statement is rather big and may be improved. As far as I could check, it seams that requested data are already correctly indexed.
Would you like that I share collected logs?
I also noticed that sometimes, that request is quite ok in terms of perfomance, sometimes not... Locally (with a standard QEA file), it could also be sometimes slower.
« Reply #3 on: September 26, 2024, 09:56:38 pm »
Not necesarrily here, but I would send a bug report to Saprx with all dat info.
Hopefully they can either improve the query, or the database schema.
jas11
« Reply #4 on: September 04, 2025, 12:00:07 am »
Wondering if the OP received a resolution to this? We're facing a similar problem with IBDs using v17.1. Operations such as adding item flows between ports or showing/hiding ports themselves are taking up to 30s to complete :(
