Author Topic: Assign Composite Diagram to Grouping  (Read 20787 times)
Viking
« on: November 13, 2024, 12:53:07 am »
In "https://sparxsystems.com/forums/smf/index.php/topic,48647.0.html" we agreed that a Grouping is a composite element.
I would like to assign a Composite Diagram to it (more for navigation purposes (double-click) than really to reflect a composition). But this is not offered by SparxEA out of the box, which should be from my point of view.
My questions are:
1) can this be achieved via a database entry?
2) is there anything else to achieve this behavior? Hyperlink is the only way I have seen so far, but even as a group the assigned element it does not look or behave as desired).
Many thanks in advance, V.
Re: Assign Composite Diagram to Grouping
« Reply #1 on: November 13, 2024, 01:09:32 am »
In the past I've successfully added composite diagrams to things that were not supposed to have composite diagrams using the API (or database updates through Repository.Execute)
I didn't test with ArchiMate Groupings, but there's a good chance it will still work.
Viking
« Reply #2 on: November 13, 2024, 02:12:11 am »
Thanks, @Geert. Like this?
groupingElement.CompositeDiagram = existingDiagram.DiagramID
« Last Edit: November 13, 2024, 04:28:25 am by Viking »
Viking
« Reply #3 on: January 28, 2025, 11:09:21 pm »
It works with the correct command:
String guid = "...";
element.SetCompositeDiagram(guid);
