Author Topic: Find all diagrams an Element is in.  (Read 12610 times)
Ruff
« on: December 12, 2024, 02:00:15 am »
If an element is in a package, how can you script a way to located all the diagrams that it's contained in?
(I'm aware of Element.Diagrams and I'm not looking for sub-diagrams of the element, I'm talking across the repository.)
Would using the Element.Connectors.DiagramID be the answer or does the Connectors DiagramID hold another meaning?
Re: Find all diagrams an Element is in.
« Reply #1 on: December 12, 2024, 02:19:09 am »
You use Repository.SQLQuery to get the ID's of all the diagrams that have a diagramObject with your elements ElementID.
Connector.DiagramID is basically only used by messages in sequence diagrams
Ruff
« Reply #2 on: December 12, 2024, 03:08:08 am »
I found your previous post on the subject.
I was able to get working code:
const regex = /<Diagram_ID>(.*?)<\/Diagram_ID>/g;
function parseDiagramIDs(xmlString) { //XML Parsers were not working for me so I modified to use regex.
    // Define a regex pattern to match all <Diagram_ID> tags and capture their values
    const diagramIDs = [];
    let match;
    // Execute regex and push all matches to the array
    while ((match = regex.exec(xmlString)) !== null) {
        if (match[1]) {
            diagramIDs.push(match[1]); // Push the captured value (Diagram ID) to the array
    if (diagramIDs.length === 0) {
        throw new Error("No Diagram_IDs found in the XML.");
    return diagramIDs.map( id => new Number(id));
 function iutils_GetDiagramOccurences(anObject) {
var num_diagrams;
var theObject As EA.Element;
theObject = anObject;
// Construct and execute the query
var sql = "";
sql += " select do.Diagram_ID "
     + " from t_diagramobjects do "
     + " where do.Object_ID = " + theObject.ElementID+ ";"
var queryResult = Repository.SQLQuery( sql );
var diagramIdsNum = [];
if ( queryResult.length > 0 )
//Session.Output(queryResult)
diagramIdsNum = parseDiagramIDs( queryResult );
return diagramIdsNum;
