Author Topic: Automatically generating a logical data model from a physical data model in Spar  (Read 17479 times)
Tarzan
Hello everyone,
I am working with Sparx Enterprise Architect version 16.1 and I’m wondering if it’s possible to automatically generate a logical data model based on an existing physical data model. I have already created the physical data model, but I would like to know if there is a way to automate the conversion to a logical data model within the software, or if I need to do this manually.
Has anyone had experience with this functionality, or can anyone provide tips or tricks to make this process easier?
Thanks in advance!
I would probably write a script.
I guess you can copy the physical datamodel, remove the table+column stereotypes, and update the types of the attributes.
Then replace the FK's by associations, and you have a start of a logical model.
Shouldn't be too hard to write a one time conversion.
What is harder (or even impossible?) is to write something to synchronize an existing logical data model with an updated physical data model.
Modesto Vega
You could use a script or a Model Transformation, the script is easier but a Model Transformation is more concise. I have used both and, for bulk generation, have a slight preference for the latter but I know other forum contributors do not agree.
The quality of your logical data model is going to depend on a number of factors:
  • Are the physical table and attribute names meaningful - e.g., Peron, tbl_Person, LastName, Last_Name, FirstName, First_Name? If they are transforming them via a script or a Model Transformation should not be too complicated.
  • Does you physical data model include relationships between tables - i.e., foreign keys? Is referential integrity enforced in the database layer? If it does, transforming the relationship with a script or a transform should also not be too complicated with one notable exception - please see below.
Unfortunately, Sparx EA does not have an elegant and easy to use out-of-the box way of handling multi-barrel foreign keys/relationships.
It is possible to synchronise the logical and physical models, as well as the database structures, with Sparx EA but you need to do all your data modelling in it.
