Author Topic: Issues with GUID of onnectors / relationships  (Read 97357 times)
Viking
Re: Issues with GUID of onnectors / relationships
« Reply #15 on: June 11, 2025, 01:04:44 am »
It did neither work on eap nor on MariaDB. I will try again.
Viking
« Reply #16 on: June 11, 2025, 04:23:21 am »
Hi @Geert, many thanks for your patience. On my installation these attributes doe not exist:
SELECT * FROM t_diagramlinks ->  t_diagramlinks does not have a Connector_lD, use Instance_ID instead
SELECT * FROM t_connector -> t_connector does not have a ConnectorID, but a Connector_ID instead
So this SQL-statement works:
SELECT d.ea_guid AS DiagramName
FROM ((t_diagramlinks dl
JOIN t_diagram d ON dl.DiagramID = d.Diagram_ID)
join t_connector c on c.Connector_ID = dl.Instance_ID)
WHERE c.ea_guid = '{BEFFA34C-4A29-46d0-AE21-96723A6FEC29}'
I thought that I was using the newest schema. I just set it up newly yesterday.
« Last Edit: June 11, 2025, 03:48:08 pm by Viking »
« Reply #17 on: June 11, 2025, 07:26:32 am »
Instance_ID is something else. You need connectorID
I just verified, and this one actually works
SELECT *
join t_connector c on c.Connector_ID = dl.ConnectorID)
The schema is unfortunately not consistent with the usage of underscores. Most of the times there's an underscore in "_ID" but sometimes not.
Viking
« Reply #18 on: June 17, 2025, 04:29:07 am »
@Geert, I got yours to work. But I had to change c.connectorID into c.connector_ID.
