Author Topic: Stereotype is not shown in the correct toolbox page  (Read 47667 times)
« on: May 26, 2025, 11:33:32 pm »
Details:
I have defined my own diagram type and toolbox.
Then I defined a view specification extending my diagram, that exposes certain stereotypes.
For the most part this works fine, except for one connector stereotype: ArchiMate3::ArchiMate_Realization
All stereotypes show up in the toolbox page I had defined for them, except for the Realization. That comes up in the toolbox page with the name of my view specifications (as if I didn't add it to a toolbox page)
Steps to reproduce
- Import the attached MDG technology file
- Create a new diagram of type Architecture::Solution Context Viewpoint
- Notice the Realization in the toolbox page Solution Context Viewpoint (instead of the toolbox page Structural Relationships"
Reported
Did anyone encounter this issues and know a solution?
Re: Stereotype is not shown in the correct toolbox page
« Reply #1 on: May 27, 2025, 09:22:04 pm »
I found the issue. I had defined the toolbox item as
- ArchiMate_Realization(UML::Realization)
But in after looking in the MDG technology for ArchiMate 3, I found that the stereotype ArchiMate_Realization was actually an extension of UML Dependency, and not of UML Realization.
After changing my toolbox item definition to
- ArchiMate_Realization(UML::Dependency)
The problem was solved.
« Reply #2 on: May 28, 2025, 08:38:24 am »
Yes, I've been caught by that kind of "discrepancy" before.  Can you see any rationale for this?  (not blaming Sparx, just observing anomaly in the standard)
« Reply #3 on: May 28, 2025, 03:34:54 pm »
Not really. The weird thing was that it worked perfectly as a toolbox item, so there was no reason to suspect it was defined wrong.
Usually if you type half a comma wrong in the MDG game, it doesn't work at all (without telling you the reason of course)
Viking
« Reply #4 on: June 04, 2025, 12:26:39 am »
Quote from: Paolo F Cantoni
I am not the expert, but the reason could be that "Dependency" is a "Type" and "Realization" a "Subtype".
« Last Edit: June 04, 2025, 02:43:23 am by Viking »
