Author Topic: Document Fragment with custom query and a result set (multiple Dataset_ / rows)  (Read 24687 times)
Daiim
I try to generate a table of neighbors for a given element via document generation, but only get one entry as a result.
The document template is called for each element and uses a Custom Query (more precise a Custom Script) being called with the #OBJECTID# as parameter.
The script iterates over all neighbors via API and returns a XML for a list of entities, e.g. { Application : "Sparx EA", Vendor: "SparxSystems", Homepage: "https://sparxsystems.com" }.
The XML structure is:
<?xml version="1.0" encoding="UTF-8"?>
<EADATA>
    <Dataset_0>
        <Data>
            <Row>
                <Application>Sparx EA</Application>
                <Vendor>SparxSystems</Vendor>
                <Homepage>http://sparxsystems.com</Homepage>
            </Row>
        </Data>
    </Dataset_0>
    <Dataset_1>
        <Data>
            <Row>
                <Application>Word</Application>
                <Vendor>Microsoft</Vendor>
                <Homepage>https://microsoft.com</Homepage>
            </Row>
        </Data>
    </Dataset_1>
</EADATA>
The script template uses a table with a table header and a single row with the custom fields {Application}, {Vendor} and {Homepage}.
What must I do, that all results (Dataset_0 to Dataset_i) are rendered as rows into the table?
Thank you very much for any hint or tip!
Best regards,
Daiim
AFAIK you can only use one dataset per fragment (but with multiple rows)
You just repeat the <row>
Daiim
Thank you Geert, this was the point.  :D
