Author Topic: Diagram Layout using Javascript NOT using the Built-In layouts  (Read 41915 times)
MichaelMurrayNL
Hopefully we can all agree that the automatic layouts in sparx is terrible, basic at best.
 - I am trying to do some custom auto-layout scripts by setting left,right,top,bottom coordinates of objects.
 - I have learned/understand that the x axis needs to be negative.
 - I have learned/understand that if anything goes "wonky" that the object is restored to some default location at the top left.
 - I have mined all the previous posts, but could not find a good resource.[/li][/list]
My question:  Has anyone done something similar or know of a good piece of documentation or examples.  Can you point me in the right direction.
Here is what I want to do.
 - I would like to move the objects to a specific location.
 - I would like to move evenly space endpoints (to prevent them being on top of each other)
 - I would like to move objects without accidently moving "nested" objects.
 - I would like to "unnest objects" if needed, multiple levels deep.
 - I would like to "nest objects" when needed, multiple levels deep.
 - I would like to align objects with an offset (like a tree structure). (Maybe I can do it with my first request manually)
Any helpful comments will be appreciated.
Re: Diagram Layout using Javascript NOT using the Built-In layouts
« Reply #1 on: March 30, 2026, 10:59:23 am »
y axis, not x.
If any code puts an element into a position it can't possibly be displayed, it gets fixed.
You've already identified everything you need to do what you want except for Sequence. The good news and bad news is that you don't get anything for free. If you change the position of one DiagramObject it won't change the position of any others.
The documentation is at https://sparxsystems.com/enterprise_architect_user_guide/17.1/add-ins___scripting/diagramobjects.html
That's everything EA offers you for the layout of objects.
What you're about to discover is that laying out a graph in general is a hard problem and you can't solve all the problems using a single algorithm because the different goals of a layout are mutually exclusive. Adding nesting/denesting of nodes adds to the list of problems that you'll encounter.
« Reply #2 on: March 30, 2026, 05:15:56 pm »
I've had some fun with layouting diagrams, in scripts.
It is basically simple geometry on two axis. You simply have to do the work.
It's not difficult, but a lot of work to get right. And more often then not, a certain layouting algorithm will work only in a specific type of diagram, with a specific type of elements on there.
I think the only way we will successfully solve this, is to include an AI agent that can make human-like decisions.
The hardest part however is not the placement of the elements, but the layout of the connectors. That is a whole different ballgame.
Here's a script with some functions to layout a diagram. It might give you some inspiration.
!INC Local Scripts.EAConstants-VBScript
!INC Wrappers.Include
' Script Name: Format BOPF diagram
' Author: Geert Bellekens
' Purpose: Format a diagram containing BOPF elemnets
' Date: 2021-03-05
const width = 100
const verticalPadding = 10
const horizontalPadding = 200
dim lsDirectMode, lsAutoRouteMode, lsCustomMode, lsTreeVerticalTree, lsTreeHorizontalTree, _
lsLateralHorizontalTree, lsLateralVerticalTree, lsOrthogonalSquareTree, lsOrthogonalRoundedTree
lsDirectMode = "1"
lsAutoRouteMode = "2"
lsCustomMode = "3"
lsTreeVerticalTree = "V"
lsTreeHorizontalTree = "H"
lsLateralHorizontalTree = "LH"
lsLateralVerticalTree = "LC"
lsOrthogonalSquareTree = "OS"
lsOrthogonalRoundedTree = "OR"
dim defaultStyle
' set here the default style to be used
defaultStyle = lsOrthogonalSquareTree
function formatBOPFDiagram(diagram)
 'inform user
 Repository.WriteOutput outPutName, now() & " Starting formatting diagram '" & diagram.Name & "'" , 0
 'auto layout diagram to get correct sizes
 dim diagramGUIDXml
 'The project interface needs GUID's in XML format, so we need to convert first.
 diagramGUIDXml = Repository.GetProjectInterface().GUIDtoXML(diagram.DiagramGUID)
 'Then call the layout operation
 Repository.GetProjectInterface().LayoutDiagramEx diagramGUIDXml, lsDiagramDefault, 4, 20 , 20, false
 diagram.Update
 'reload the diagram to make sure it works in all cases
 set diagram = Repository.GetDiagramByID(diagram.DiagramID)
 dim diagramObjects
 set diagramObjects = getDiagramObjectsDictionary(diagram)
 'get the diagramObject for the owner of the diagram
 dim diagramObjectOwner as EA.DiagramObject
 if diagramObjects.exists(diagram.ParentID) then
  set diagramObjectOwner = diagramObjects.Item(diagram.ParentID)
  'get diagram object object
  dim diagramOwner as EA.Element
  set diagramOwner = Repository.GetElementByID(diagram.ParentID)
  dim x
  dim y
  'determine start position based on the owner's stereotype
  if diagramOwner.Stereotype = "BOPF_businessObject" then
   x = 10 'start top left for business object
  else
   x = 600 'start in the middle for node
  end if
  y = -10
  dim height
  height = abs(diagramObjectOwner.bottom) - abs(diagramObjectOwner.Top)
  'set first position
  diagramObjectOwner.left = x
  diagramObjectOwner.right = x + width
  diagramObjectOwner.top = y
  diagramObjectOwner.bottom = y - height
  diagramObjectOwner.Update
  'process sub elements
  formatSubElements diagramOwner, diagramObjectOwner, diagram, diagramObjects
  'process combined datatype
  if diagramOwner.Stereotype = "BOPF_node" then
   formatDatatype diagramOwner, diagram, diagramObjects
  end if
  ' Process authorizations. Usually there is only one authorization object per node. For now layout on each other
  formatAuthorizationObjects diagram, diagramObjects
 end if
 'format links
 formatLinks diagram
 'reload diagram
 diagram.Update
 Repository.ReloadDiagram diagram.diagramID
 'inform user
 Repository.WriteOutput outPutName, now() & " Finished formatting diagram '" & diagram.Name & "'" , 0
end function
function formatLinks(diagram)
 dim test as EA.DiagramLink
 dim diagramLink as EA.DiagramLink
 for each diagramLink in diagram.DiagramLinks
  'get the connector
  dim connector as EA.Connector
  set connector = Repository.GetConnectorByID(diagramLink.ConnectorID)
  setConnectorStyle diagramLink, connector
  if connector.Stereotype = "SAP_association" then
   formatAssociationLink(diagramLink)
  end if
 next
end function
function formatAssociationLink(diagramLink)
 'get the order of the diagram link
 dim sqlGetOrder
 sqlGetOrder = "select con.seq from        " & vbNewLine & _
     " (        " & vbNewLine & _
     " select c2.Connector_ID, ROW_NUMBER() over (order by c2.Name, c2.Connector_ID)  as seq   " & vbNewLine & _
     " from t_connector c        " & vbNewLine & _
     " inner join t_connector c2 on c2.Start_Object_ID = c.Start_Object_ID                    " & vbNewLine & _
     "       and c2.End_Object_ID = c.End_Object_ID                           " & vbNewLine & _
     "       and c2.Stereotype = c.Stereotype                                 " & vbNewLine & _
     " inner join t_diagramlinks dl on dl.ConnectorID = c2.Connector_ID                       " & vbNewLine & _
     "       and dl.DiagramID = " & diagramLink.DiagramID & "                 " & vbNewLine & _
     " where c.Connector_ID = '" & diagramLink.ConnectorID & "'                                " & vbNewLine & _
     " ) con        " & vbNewLine & _
     " where con.Connector_ID = '" & diagramLink.ConnectorID & "'                              "
 dim results
 set results = getArrayListFromQuery(sqlGetOrder)
 dim order
 order = results(0)(0)
 if order <> "1" then
  'get key value pairs for geometry
  dim geometryKeyValues
  set geometryKeyValues = getKeyValuePairs(diagramLink.Geometry)
  'move ey and ex
  dim ey
  ey = cInt(geometryKeyValues("EY"))
  ey = ey - cint(order) * 20 'move end down
  geometryKeyValues("EY") = ey
  dim ex
  ex = cInt(geometryKeyValues("EX"))
  ex = ex - cint(order) * 20 'move end left
  geometryKeyValues("EX") = ey
  'then join again
  diagramLink.Geometry = joinKeyValuePairs(geometryKeyValues)
  'and update
  diagramLink.Update
 end if
end function
'actually sets the connector style
function setConnectorStyle(diagramLink, connector)
 if diagramLink is nothing then
  exit function
 end if
 'split the style into its parts
 dim styleparts
 dim styleString
 ' Throw away the last ; so that an empty cell at the end is not created when its Split
 if len(diagramLink.Style) > 0 then
  styleString = Left(diagramLink.Style, Len(diagramLink.Style)-1)
 else
  styleString = ""
 end if
 styleparts = Split(styleString,";")
 dim mode
 dim tree
 dim linestyle
 mode = ""
 tree = ""
 linestyle = determineLineStyle(connector)
 'get out if no linestyle found
 if len(linestyle) = 0 then
  setConnectorStyle = false
  exit function
 end if
 'these connectorstyles use mode=3 and the tree
 if  linestyle = lsTreeVerticalTree or _
  linestyle = lsTreeHorizontalTree or _
  linestyle = lsLateralHorizontalTree or _
  linestyle = lsLateralVerticalTree or _
  linestyle = lsOrthogonalSquareTree or _
  linestyle = lsOrthogonalRoundedTree then
  mode = "3"
  tree = linestyle
 else
  mode = linestyle
 end if
 'set the mode value
 setStylePart styleparts, "Mode", mode
 'set the tree value
 setStylePart styleparts, "TREE", tree
' setStylePart styleparts, "Color", determineColor(connector)
' setStylePart styleparts, "LWidth", determineLineWidth(connector)
 ' update style (add in trailing ; that is needed)
 diagramLink.Style = join(styleparts, ";") & ";"
 'clear path and geometry
 diagramLink.Geometry = ""
 diagramLink.Path = ""
 'save diagramLink
 diagramLink.update
 'return true for dirty
 setConnectorStyle = true
end function
function determineLineStyle(connector)
 determineLineStyle = "" 'default none
 'only do non stereotyped relations
 if connector.Stereotype = "SAP_composition" then
  determineLineStyle = lsLateralHorizontalTree
 elseif connector.Stereotype = "BOPF_authorizationCheck" then
  determineLineStyle = lsOrthogonalSquareTree
 else
  determineLineStyle = lsDirectMode
 end if
end function
' Set the style to the specified value
function setStylePart(styleparts, style, value)
 dim i
 dim stylePart
 dim index
 index = -1
 for i = 0 to Ubound(styleparts)
  stylePart = styleparts(i)
  if Instr(stylepart, style & "=") > 0 then
   index = i
  end if
 next
 If Len(value) > 0 then
  ' Adding to style
  if index = -1 then
   ' extend the array when style is not already in array
   redim preserve styleparts(Ubound(styleparts) + 1)
   index = Ubound(styleparts)
  end if
  styleparts(index) = style & "=" & value
 else
  ' Removing style from styleparts
  if index >= 0 then
   ' copy the last value over the top of index, and then shrink the array
   styleparts(index) = styleparts(Ubound(styleparts))
   redim preserve styleparts(Ubound(styleparts) - 1)
  end if
  ' if the index was -1 it already did not exist in the styleparts
 end if
end function
function formatSubElements(diagramOwner, diagramObject, diagram, diagramObjects)
 dim symmetric
  symmetric = true
 else
  symmetric = false
 end if
 'get list of ID's that are owned by this diagramObject, and that are part of the diagram
 dim diagramElementIDs
 diagramElementIDs = Join(diagramObjects.Keys, ",")
 dim sqlGetData
 sqlGetData = "select o.Object_ID                                " & vbNewLine & _
   " from (select o.Object_ID, o.Name, o.stereotype,       " & vbNewLine & _
   " case when o.stereotype = 'BOPF_determination' then 1  " & vbNewLine & _
   " when o.stereotype = 'BOPF_validation' then 2          " & vbNewLine & _
   " when o.stereotype = 'BOPF_action' then 3              " & vbNewLine & _
   " else 99 end as seqOrder                               " & vbNewLine & _
   " from t_object o                                       " & vbNewLine & _
   " where o.ParentID = " & diagramObject.ElementID & "    " & vbNewLine & _
   " and o.Object_ID in (" & diagramElementIDs & ")        " & vbNewLine & _
   " ) o                                                   " & vbNewLine & _
   " order by o.seqOrder, o.stereotype, o.name             "
 dim subElementIDs
 set subElementIDs = getVerticalArrayListFromQuery(sqlGetData)
 dim subElementID
 dim x
 dim y
 y = diagramObject.bottom
 dim height
 if subElementIDs.Count > 0 then
  dim subDiagramObject as EA.DiagramObject
  'determine max width
  dim maxWidth
  maxWidth = 0
  for each subElementID in subElementIDs(0)
   set subDiagramObject = diagramObjects(CLng(subElementID))
   dim elementWidth
   elementWidth = subDiagramObject.right - subDiagramObject.left
   if elementWidth > maxWidth then
    maxWidth = elementWidth
   end if
  next
  if symmetric then
   'format elements
   dim position
   position = 0 '0 = left, 1 = right, 2 = far left, 3 = far right
   dim xValues
   set xValues = CreateObject("System.Collections.ArrayList")
   dim center
   center = (diagramObject.left + diagramObject.right) /2
   dim minBottom
   minBottom = diagramObject.Bottom - (verticalPadding * 3)
   'format elements
   xValues.Add(center - horizontalPadding) '0
   xValues.Add(center + horizontalPadding) '1
   xValues.Add(center - (horizontalPadding * 2))'2
   xValues.Add(center + (horizontalPadding * 2))'3
   y = diagramObject.bottom - verticalPadding
    'go down on the first and and 3th position
    if position = 0 or position = 2 then
     y = minBottom - verticalPadding
    end if
    x = xValues(position)
    height = abs(subDiagramObject.bottom) - abs(subDiagramObject.Top)
     subDiagramObject.left = x
     subDiagramObject.right = x + maxWidth
    else
     subDiagramObject.left = x - maxWidth
    end if
    subDiagramObject.top = y
    subDiagramObject.bottom = y - height
    subDiagramObject.update
    if subDiagramObject.bottom < minBottom then
     minBottom = subDiagramObject.bottom
    end if
    'reset position after 3
    if position = 3 then
     position = 0
    else
     position = position + 1
    end if
   next
  else
   'format elements
   x = diagramObject.right + (horizontalPadding /2)
    y = y - verticalPadding 'go down
    y = subDiagramObject.bottom
    'go one level deeper
    y = formatSubElements(diagramOwner, subDiagramObject, diagram, diagramObjects)
   next
  end if
 end if
 'return Y
 formatSubElements = y
end function
function formatDatatype(diagramOwner,diagram, diagramObjects)
 dim sqlGetData
   " where o.Object_Type = 'Datatype'                      " & vbNewLine & _
 dim datatypeIDs
 set datatypeIDs = getVerticalArrayListFromQuery(sqlGetData)
 dim datatypeID
 dim x
 x = 1200
 dim y
 y = -20
 if datatypeIDs.Count > 0 then
  for each datatypeID in datatypeIDs(0)
   dim diagramObject as EA.DiagramObject
   set diagramObject = diagramObjects(CLng(datatypeID))
   dim height
   height = abs(diagramObject.bottom) - abs(diagramObject.Top)
   dim width
   width = diagramObject.right - diagramObject.left
   diagramObject.left = x
   diagramObject.right = x + width
   diagramObject.top = y
   diagramObject.bottom = y - height
   diagramObject.Update
  next
 end if
end function
''debug
'sub test
' dim diagram as EA.Diagram
' set diagram = Repository.GetDiagramByGuid("{50315683-1BB7-4557-B6A3-06FAFB9A6E23}")
' formatBOPFDiagram(diagram)
'end sub
'test
'formatAuthorizationObjects
function formatAuthorizationObjects (diagram, diagramObjects)
 '1. Find all authorisation objects on the diagrams
 dim sqlGetData
 sqlGetData= "select o.Object_ID                                " & vbNewLine & _
    " where o.Stereotype = 'SAP_authorizationObject'   " & vbNewLine & _
 dim authorizationObjectIDs
 set authorizationObjectIDs = getVerticalArrayListFromQuery(sqlGetData)
 '2. Find the BO node connected to the authorization object
 if authorizationObjectIDs.Count > 0 then
  for each authorizationObjectID in authorizationObjectIDs(0)
   set diagramObject = diagramObjects(CLng(authorizationObjectID))
   'Find BO node
   'Find BO node id
      " inner join t_connector c                          " & vbNewLine & _
      " on c.Start_Object_ID = o.Object_ID                " & vbNewLine & _
      " where o.Stereotype = 'BOPF_node'                  " & vbNewLine & _
      " and c.End_Object_ID = "& authorizationObjectID
   dim BONodeIDs
   set BONodeIDs = getVerticalArrayListFromQuery(sqlGetData)
   if BONodeIDs.Count > 0 then
    dim BONodeID
    for each BONodeID in BONodeIDs(0)
     dim diagramObjectBONode as EA.DiagramObject
     set diagramObjectBONode = diagramObjects(CLng(BONodeID))
     dim height
     dim width
     dim x
     x = diagramObjectBONode.right + 300
     dim y
     y = diagramObjectBONode.top
     '3. Set the top coordinate of the authorization object equal to the ones of the bo node but more to the right.
     exit for
    next
   end if
  next
 end if
end function
MichaelMurrayNL
« Reply #3 on: March 31, 2026, 09:41:31 pm »
Thanks Geert.  Useful reply!
I realize I will have to do the hard work now....
