Author Topic: API EA.Diagram Method to get the Focus/reference selected object  (Read 67190 times)
Guillaume
    • www.umlchannel.com
With a diagram script I can control and access the selected objects with diagram.SelectedObjects.
I'd like to get the focus/reference object e.g. if you select several classes, unselect and reselect one, it is shown with a hatched border. It doesn't seem to be possible to find this object in the script. Could a method be provided to do so ?
Guillaume
Re: API EA.Diagram Method to get the Focus/reference selected object
« Reply #1 on: July 13, 2026, 09:37:39 am »
Repository.GetContextItem() and Repository.GetContextObject() both give you the object that has its properties displayed. That could be the object you've asked for but it could also be the browser selection.
If you want to be more precise use
Repository.CurrentSelection
It was designed to address the limitation that we offer Diagram.SelectedObjects and the Repository functions mentioned above but no way to get multiple selection in other places. That's important because it gives you enough information to know if the focused element in on a diagram.
If I had your need with EA "as is", I would use something like this:
function FocusedElement {
    if( Repository.CurrentSelection.Location == "Diagram")
        return Repository.GetContextObject();
    else
        return null;
Guillaume
« Reply #2 on: July 17, 2026, 04:53:27 pm »
Hi Eve,
Thank you for the advice. I confirm that Repository.GetContextObject(); returns the "reference" element from the diagram.
Guillaume
