Author Topic: Adding Elements to a diagram  (Read 14464 times)
Bhupinder
« on: May 18, 2004, 08:00:39 pm »
Can anyone one let me know why I am getting this stange behaviour?
I am adding (through an EA Addin) several new DiagramObjects linking Existing Elements to Current diagram.
But the current diagram does not show my new elements - I am calling Update on both the new DiagramObject and the Diagram.
However if I ask EA to reload the same diagram (from context menu on diagram tabs in the diagram window) my newly added elements appear.
I have also tried calling Repository.ReloadDiagram but this makes no difference.
Would appreciate any help
thank you
Baz
Bhupinder
Re: Adding Elements to a diagram
« Reply #1 on: May 19, 2004, 06:24:33 am »
Some more info.
The Reload Diagram (&SaveDiagram) only fails to display the newly inserted diagram objects if the elements being added are not contained within the same package as the diagram.
Here is the sample Delphi code I am working on
var i, q : integer;
   Diagram     : IDualDiagram;
   DiagramObjs : IDualCollection;
   DiagramObj : IDualDiagramObject;
   Proj       : IDualProject;
   Exists     : Variant;
begin
 inherited;
 Diagram := Repository.GetCurrentDiagram;
 DiagramObjs := Diagram.DiagramObjects;
 //iterate through tree adding all the selected elements
 for i := 0 to pred (ElementList.Count) do
 begin
        //check if element has already been added
        q := 0;
        Exists := False;
        while ( q<= pred(DiagramObjs.Count)) and (Exists = Null) do
        begin
            Exists := IDualDiagramObject( DiagramObjs.GetAt(q) ).ElementID = Integer( ElementList.Objects );
            INC (q);
        end;
        if NOT Exists then
        begin
     //create the new diagram object and link to element / diagram
DiagramObj := DiagramObjs.AddNew(
                       format ( 'l=%d;r=%d;t=200;b=270;' ,[(130*i), (130*i) + 120 ]) , '')
        as IDualDiagramObject;
          DiagramObj.ElementID := Integer(ElementList.Objects);
          DiagramObj.DiagramID := Diagram.DiagramID;
          if not DiagramObj.Update then
             Showmessage( DiagramObj.GetLastError );
          if not Diagram.Update then
             Showmessage( Diagram.GetLastError );
        end;
 end;
 Repository.CloseDiagram (Diagram.DiagramID);
 Repository.OpenDiagram (Diagram.DiagramID);
 // Repository.ReloadDiagram(Diagram.DiagramID);
//layout the diagram
 Proj := repository.GetProjectInterface;
 Proj.LayoutDiagram(Diagram.DiagramGUID, 64);
Thanks in advance for any explainations.
Gobo
« Reply #2 on: May 24, 2004, 04:45:08 am »
Hey,
Additional question as far as LayoutDiagram is concerned.  Do You know how to set diagram properties, such as "Hide Attributes" or " Hide Operations". I can't find them inside EA.Diagram class.
Gobo
« Last Edit: May 24, 2004, 04:45:55 am by Gobo »
