Author Topic: Problem getting 'Static View' Element in EA 4.0  (Read 13592 times)
khalidlkhan
« on: June 01, 2004, 04:55:42 am »
I have just migrated to EA 4.0 and find that some VB that I wrote to query EA for model data now no longer works.
Quite simply I would like to get the EAElement for the 'Static View' package. I used the following code:
Set p = EAR.Models.GetByName("Views")
Set e = p.elements.GetByName(“Static View”)
As I said this used to work but I now get the error:
DAO.Database [3075] Syntax error (missing operator) in query expression 'Name='Static View' AND Object_ID in ()'
I had reported this as a bug - but I think it must have fallen on the low priority list or it may be that this was not a bug but that things are done differently in EA 4.0.
I am posting this in case it is the latter.
(I am working with the assumption that if this was a bug then EA 4.0 would have stopped alot of VBA integrated stuff out there and this would have been seen as slightly higher priority.)
Any help greatly appreciated.
Khalid
charge
Re: Problem getting 'Static View' Element in EA 4.
« Reply #1 on: June 10, 2004, 02:58:04 am »
I have my own function to find a package by name:
   Private Sub btnExport_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnExport.Click
       Dim eaoEA As EA.Repository
       Dim eaAppEA As EA.App
       'open EA
       eaAppEA = CreateObject("EA.App")
       eaoEA = eaAppEA.Repository
       eaoEA.OpenFile(Me.txtPath.Text)
       'do somthing
       Dim objPackage As EA.Package
       Try
           objPackage = FindPackage(Nothing, "Data Model", eaoEA)
       Dim obj As EA.Element
       obj = objPackage.Elements.AddNew("test", "table")
       obj.Update()
       Catch ex As Exception
           MessageBox.Show(ex.ToString)
       End Try
       'close EA
       eaoEA.Exit()
       eaoEA = Nothing
   End Sub
  Private Function FindPackage(ByVal StartPackage As EA.Package, ByVal PackageName As String, Optional ByVal eaoEA As EA.Repository = Nothing) As EA.Package
       Dim objReturnPackage As EA.Package
       If StartPackage Is Nothing Then
           Dim idx As Integer
           For idx = 0 To eaoEA.Models.Count - 1
               objPackage = eaoEA.Models.GetAt(idx)
               objReturnPackage = FindPackage(objPackage, PackageName)
               If Not objReturnPackage Is Nothing Then
                   Return objReturnPackage
               End If
           Next
       Else
           If StartPackage.Name.ToLower = PackageName.ToLower Then
               Return StartPackage
           Else
               For Each objPackage In StartPackage.Packages
                   End If
               Next
           End If
       End If
   End Function
