Author Topic: [Solved] How to set "Kind" of an action  (Read 9846 times)
Sorno
« on: February 14, 2014, 07:59:49 pm »
In my MDG I let my stereotype FunctionCall extend Action. I now wish to also set Kind to BehaviorCall (as found in the properties dialog under Advanced).   I see that the metaclass Action has the attribute Kind - but changing that value don't. When I create an instance of the stereotype the Kind-field is empty.
Is it possible to set such properties from the MDG or do I need to do it through an addin?
Also, I reckon it would take an addin to make EA open a elementpicker where the user can choose which Activity to call? (This happens if you add Action (behavior call) from the UML toolbox. )
Thank you for any help!
Edit:
For the steroetype set the attribute "kind" to type ActionCall and the initial value to "CallBehavior".
« Last Edit: February 24, 2014, 07:02:07 pm by Sorno »
