Author Topic: Set Element Colour on UML Profile  (Read 6464 times)
ADucci
« on: March 25, 2014, 09:25:17 pm »
I have created a UML Profile, and on that profile, have extended a normal class meta-type with a new stereotype.
I have set the background colour of my new stereotype element and exported the profile as per:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.0/standard_uml_models/importingprofiles.html instructions
This does not seem to work as expected, the new elements color is unchanged and when looking at the profile.xml file, I see that the bgcolor property is "-1"  indicating that the colour attribute did not pull through.
Is this an EA Bug, or have I just done something wrong.
Anthony
Re: Set Element Colour on UML Profile
« Reply #1 on: March 25, 2014, 09:35:35 pm »
Shape information is only exported if you export the diagram rather than the package as profile. Maybe that is your issue?
ADucci
« Reply #2 on: March 26, 2014, 05:45:49 pm »
Problem Solved (as per EA support guys)
I was using the color palette on the toolbar to define the color,
I should have selected the element -> Appearance --> Default Appearance  to change the color.
Thanks.
