Author Topic: Heading in RTF Document Generation  (Read 15442 times)
kepNCI
« on: June 05, 2014, 06:00:15 am »
In my RTF template, I set the package name to "Heading 1". The RTF generator correctly creates the child package name with the Heading 2, Heading 3, etc.
I am using a style sheet template to define the Headings. Only Heading 1 has a page break preceding it.
When the RTF generator creates the output document, it assigns the correct Heading x style to the package name and displays the correct formatting, EXCEPT, the generator is formatting a page break for all Headings, not just Heading 1. I am assuming this is a bug in that it is picking up the Page Beak defined for Heading 1 and applying it to all Heading x created for the child packages.
FYI:: While I am using v11 and style templates, I think the same issue was in earlier releases when I defined the header styles as part of the main template. It also does not make any difference which document type you select for the output.
