Author Topic: Association Component -> Package within AI  (Read 13981 times)
mamomuc
« on: September 20, 2004, 09:08:59 am »
Hi there,
I try to make a association between a component an a package within the automation interface. The result is, that the connection exist if I check the connector, but in the link-view of the package or the component no relation is visible.
Has someone an idea how I can make the association visible?
I make the association with the following commands (variables are replaced´):
set connector = component.connectors.addnew(package.name, "Association")
connector.supplierID = package.packageID
Cheers
Markus
Re: Association Component -> Package within AI
« Reply #1 on: September 20, 2004, 04:07:39 pm »
Try adding as the next two lines:
connector.Update
component.connectors.Refresh
Hope that works for you.
mamomuc
« Reply #2 on: September 21, 2004, 12:03:40 am »
Hi KP,
thanks for the tip. I have already tried to refresh and update the elements. The result has no effect.
Another idea?
Markus
« Reply #3 on: September 21, 2004, 05:35:08 pm »
If you e-mail the part of your code that isn't working, we can have a closer look: [email protected]
