Author Topic: C++ code generation  (Read 12848 times)
cazo
C++ code generation
« on: September 29, 2004, 05:16:34 pm »
Hi there!
I'm trying to generate the C++ code prototype from
a single class (I don't know if t's better); so, the class
is generated correctly, but I cannot see any tag that
will preserve my code. In other hand, when
regenerating my code, it repeats any time, the same
line,... like this:
char str[10]; // I change to size 20...
char str[20]; // it puts the line again...
char str[20]; // it was regenerated... and so on.
any tips?
-- Claudio
Cláudio Cardozo
Re: C++ code generation
« Reply #1 on: September 30, 2004, 12:34:41 am »
Hi Claudio,
I don't know this for sure, but it looks to me like you're setting the name as 'str[10]' etc.  What you need to do is set the name to str and then on the Detail tab in the attributes dialog box tick 'Attribute is a Collection' and set the container type to '[10]'.
If I do that then it synchronises the changes to the container type perfectly.
Simon
cazo
« Reply #2 on: September 30, 2004, 07:29:59 pm »
Hi Simon, works fine after your tip; thanx! :)
So... but the same doesn't happen with the methods...
look below, please.
Hello.h
//  Implementation of the Class Hello
//  Created on:      26-set-2004 21:37:42
//  Original author: Claudio
#if !defined(A6413818_42A5_47fe_9FDD_C8F6F19171C3__INCLUDED_)
#define A6413818_42A5_47fe_9FDD_C8F6F19171C3__INCLUDED_
#include <stdio.h>
#include <string.h>
* Here should be the comments relative to the class...
class Hello{
public:
     void SetSomeThing(const char *str);
     void SetSomeThing(const char *str); // repeats
     Hello();
     virtual ~Hello();
     void SayHello();
     void SetSomeThing(char *str);
private:
      * string to contain a word
      * It's ok; in the tab Detail I setted:
      * lower bound=1 upper bound=20 and
      * container type= [30] and checked
                * "attribute is a collection"
     char str[30];
#endif // !defined(A6413818_42A5_47fe_9FDD_C8F6F19171C3__INCLUDED_)
-- Claudio
Cláudio Cardozo
cazo
« Reply #3 on: September 30, 2004, 07:35:09 pm »
Ops, the body code, the generation repeats
each method definition... below:
//  Hello.cpp
#include "Hello.h"
* Constructor
Hello::Hello(){
* Destructor
Hello::~Hello(){
// ATTENTION HERE!!!
// this method never is regenerated!!!
// it keeps here!
* Display... may be hello... hello!
void Hello::SayHello(){
* set some thing (!?)
void Hello::SetSomeThing(char *str){
-- Cláudio
Cláudio Cardozo
« Reply #4 on: September 30, 2004, 10:58:50 pm »
I'm not sure what's going on for you there.  I don't have the problem.  My guess is that you have extra stuff in the type so that EA doesn't recognise that the method signature is the same and so adds a new one.
What I suggest is to try importing the code, that way you'll see how EA creates a model from that code and it expects things to be modelled in that way when it generates code again.
Simon
