Author Topic: More .NET Woes  (Read 9871 times)
Tobin_Harris
More .NET Woes
« on: October 19, 2004, 11:17:09 pm »
Hi there,
After upgrading to latest build 4.10.739, our .NET addin has suddenly stopped working.
The symptom of this is that when you launch EA, a messagebox pops up saying "There was an error loading the add-in 'Blahblah(Blah.blah)' remove it from the list?"
I've now tried rebuilding against the latest EA dlls, but am still having problems. More specifically, despite  implementing the Addin interface, I get a compile error saying that the Connect method is not implemented, but it is! So, I also tried inheriting from the AddinClass class instead, which will compile but I then get the "Error loading addin" popup when launching EA.
Any help much appreciated.I didn't see any mention of breaking changes in the docs or the realease list.
Tobin
charge
Re: More .NET Woes
« Reply #1 on: October 25, 2004, 01:54:20 am »
The likely reason for this error is that they have improved the interface to .net, and are now providing a strongly typed assembly: Interop.EA.dll.
You should de-reference EA in your VS project, and reference Interop.EA.dll from \program files\sparx systems\ea.
The interop file you compile with should also be included with your installations.
