Author Topic: EA Connector For Jira  (Read 5147 times)
Burak AYDIN
« on: February 20, 2015, 07:38:28 am »
I made mappings and trying to Import Issues. When I want to click Import Issues  there was an error showing up which was just:
"Object reference not to set an instance of an object"
After clicking ok and choice an issue
"There was an error displaying comparison table" error showing
How can I fix this?
Log here;
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at EAConnector4JiraRest.Formularios.FrmImport.CalculateTotalElements(List`1& pListaIssues)
   at EAConnector4JiraRest.Formularios.FrmImport.CargarTreeView()
   at EAConnector4JiraRest.Formularios.FrmImport.ActualizarTreeView()
   at EAConnector4JiraRest.Formularios.FrmImport.toolStripComboBoxMapeoTipo_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ToolStripComboBox.HandleSelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Assembly Version: 6.5.1.0
    Win32 Version: 6.5.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Sparx%20Systems/EA/EAConn4Jira/EAConnector4JiraRest.DLL
CommonClases
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Sparx%20Systems/EA/EAConn4Jira/CommonClases.DLL
EAConnector4JiraRest.resources
    CodeBase: file:///C:/Program%20Files%20(x86)/Sparx%20Systems/EA/EAConn4Jira/en/EAConnector4JiraRest.resources.DLL
EAConnectorForJiraDbUpgrade
    CodeBase: file:///C:/Program%20Files%20(x86)/Sparx%20Systems/EA/EAConn4Jira/EAConnectorForJiraDbUpgrade.DLL
System.Data
    Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
« Last Edit: February 20, 2015, 07:38:51 am by baydin »
Re: EA Connector For Jira
« Reply #1 on: February 20, 2015, 11:16:09 am »
You should report that as bug (link bottom right of this page). If the Jira connector is bought from a different company you should contact them also.
« Last Edit: February 20, 2015, 11:16:27 am by qwerty »
Aaron B
« Reply #2 on: February 20, 2015, 11:49:29 am »
EA Connector for JIRA is a third-party add-in developed by our sister company, Sparx Systems Spain.  You will need to contact Sparx Systems Spain for further assistance with this product.
https://en.sparxsystems.es/contacto/
Burak AYDIN
« Reply #3 on: February 20, 2015, 06:08:56 pm »
I am not a registered member of sparxsystems .I can't report bug.How can I register?
« Reply #4 on: February 20, 2015, 08:45:09 pm »
You could mail directly. If it's a bug report they (hopefully) will have a look into the issue. To register you need to buy a license.
