Author Topic: Apply layout to diagram via scripting  (Read 6545 times)
survex
« on: May 25, 2015, 04:56:16 am »
How to apply any layout (say spring) to diagram via scripting?
Re: Apply layout to diagram via scripting
« Reply #1 on: May 25, 2015, 06:20:21 am »
ProjectInterface.LayoutDiagramEx
« Last Edit: May 25, 2015, 06:21:01 am by qwerty »
survex
« Reply #2 on: May 27, 2015, 06:41:00 am »
Here's a definition of the function:
LayoutDiagramEx (string DiagramGUID, long LayoutStyle, long Iterations, long LayerSpacing, long ColumnSpacing, boolean SaveToDiagram)
And description of LayoutStyle parameter:
LayoutStyle accepts the following options
•      Default Options:
    - lsDiagramDefault
    - lsProgramDefault
•      Cycle Removal Options:
    - lsCycleRemoveGreedy
    - lsCycleRemoveDFS
•      Layering Options:
    - lsLayeringLongestPathSink
    - lsLayeringLongestPathSource
lsLayeringOptimalLinkLength
•      Initialize Options:
    - IsInitializeNaive
    - IsInitializeDFSOut
IsInitializeDFSIn
•      Crossing Reduction Option:
    - lsCrossReduceAggressive
•      Layout Options - Direction
lsLayoutDirectionUp
lsLayoutDirectionDown
lsLayoutDirectionLeft
lsLayoutDirectionRight
And what should I pass as LayoutStyle parameter? What kind of long should it be?
« Reply #3 on: May 27, 2015, 06:47:17 am »
Ah, that help... Look into the constants that are defined in the ScriptingLib MDG. Or probably you number the list which appears after ConstLayoutStyles Enum in the help.
survex
« Reply #4 on: May 27, 2015, 06:06:15 pm »
Here's the working code snippet:
!INC Local Scripts.EAConstants-JScript
function main ()
      var DiagramGUID, LayoutStyle, Iterations, LayerSpacing, ColumnSpacing, SaveToDiagram;
      var Project as EA.Project;
      Project = Repository.GetProjectInterface();
      DiagramGUID = Project.GUIDtoXML( Repository.GetCurrentDiagram().DiagramGUID );
      //See ConstLayoutStyles in EAConstants-JScript
      //LayoutStyle = lsDiagramDefault
      LayoutStyle = lsCycleRemoveDFS | lsLayeringOptimalLinkLength | lsInitializeDFSOut | lsLayoutDirectionDown;
      Iterations = 4;
      LayerSpacing = 20;
      ColumnSpacing = 20;
      SaveToDiagram = false;
      Project.LayoutDiagramEx( DiagramGUID, LayoutStyle, Iterations, LayerSpacing, ColumnSpacing, SaveToDiagram );
main();
