Author Topic: MDA templates string determination with addin  (Read 4343 times)
Oliver F.
    • Karl Storz homepage
« on: September 28, 2015, 08:39:44 pm »
There is one thing about MDA transformations which is driving me straight into crazyness: String handling via addin.
I am trying to transform classes with attributes which have default values (initialValues).
Some attribute default values are of type char[] and others are unsigned int. These attributes are processed with a C# addin.
Now to the interesting part:
The addin tries to determine whether the type is integer or char[] and returns the original, unprocessed value if it´s a string.
What I see when I read out attInitial of that attribute is an escaped string like:
"\"Hey there\"".
Sending the string back to the transformation process without modification leads to the escaping chars ('\') being stripped away and the template code
$values = %EXEC_ADD_IN("Parameter_AddIn","modifyParameterArray", attInitial)%
default = %qt%$values%qt%
leads to ""Hey there"" in the transformation log thus failing the process.
The surrounding %qt% statements are mandatory for assignments in the template so they can´t be skipped anyway and this would not be of use anyway.
Handling the string determination inside the MDA template also failed as I have been unable to find the correct escaping sequence to identify the \" sequence.
So any idea what is the correct way to return a quoted string from an addin or a clever way for string determination inside the MDA templates?
Thanks in advance.
Oliver
Re: MDA templates string determination with addin
« Reply #1 on: September 28, 2015, 09:17:37 pm »
Not that I can help here. But this is one of the reasons I stopped using this proprietary Sparxian macro language and started using scripting instead.
Oliver F.
« Reply #2 on: October 06, 2015, 06:56:17 pm »
So for the records, it looks as if a string can be returned by escaping it with
strReturn = "\\\""+strReturn+"\\\"";
which then lets you use the template with the %qt% macro:
with $values holding the string from the addin.
Funny because I had situations in which the \" sequence has been stripped away.
Seems to work now.
Oliver
