Author Topic: images in shape scripts  (Read 5018 times)
Bob Spring
« on: December 03, 2015, 10:04:28 am »
Hi
I have created several images in PNG, WMF and EMF formats and loaded them into the image viewer. If I reference them in a shape script, they all have a background colour even though the original images have a transparent background.
If I reference the registered image by manually setting an elements alternative image, it happily honours the transparent background.
Why does it work manually but not via shape scripts?
Bob
Re: images in shape scripts
« Reply #1 on: December 03, 2015, 11:21:30 am »
Probably because it's EA. Start a search on "transparent" or "transparency" on the forum. You will find quite some threads.
Bob Spring
« Reply #2 on: December 03, 2015, 08:00:51 pm »
Yes, I read most of them.
They are for older versions and imply transparency doesn't work at all.
I am using Version 12.15.
Transparency is clearly supported, just shape scripts do something odd.
Bob
« Reply #3 on: December 03, 2015, 08:07:13 pm »
Bob,
If I were you I would send a bug report to Sparx.
They usually respond pretty quickly to reports like that.
