Author Topic: Detect change of tagged value (Type=Memo)  (Read 11834 times)
phdare
« on: December 10, 2015, 04:36:05 pm »
Hi all,
I use tagged value to store large string value (more than 255 characters in length), tagged value type is 'Memo'.
However, when I change these values it doesn't fire any broadcast events. Is it possible to detect changes of tagged values (in this case Type=Memo) immediately after their values are changed?
Thank you in advance.
Re: Detect change of tagged value (Type=Memo)
« Reply #1 on: December 10, 2015, 06:00:48 pm »
One of the
  • EA_OnAttributeTagEdit
  • EA_OnConnectorTagEdit
  • EA_OnElementTagEdit
  • EA_OnMethodTagEdit
Should fire. If not you should report a bug
In the mean time you could get by using the context events. If something is in context you store it in a variable.
If something else is selected then you look at the previous context element and check if anything changed.
phdare
« Reply #2 on: December 10, 2015, 07:34:27 pm »
Hi Geert,
None of these broadcast events are called. I reported a bug for this issue.
Thank for your suggestion, I will try it.
« Reply #3 on: December 11, 2015, 08:31:38 am »
Geert, did you even read the description of those functions?
EA_OnAttributeTagEdit is called when the user clicks the ellipsis ( ... ) button for a Tagged Value of type AddinBroadcast on an attribute.
« Reply #4 on: December 11, 2015, 09:00:20 am »
Probably he didn't (like me). But there is some kind of intentional idea you get when seeing a method named EA_OnAttributeTagEdit which whispers "It will be called on modification and memo is part of that". Yuck.
« Reply #5 on: December 11, 2015, 11:36:18 am »
However (at least in English), that idea is not correct.  The OP was looking for (something like): EA_OnAttributeTagModified or EA_OnAttributeTagChanged (or even,, at a pinch: EA_OnAttributeTagEdited)
EA_OnAttributeTagEdit is a valid name for the intended purpose.
However, since most native English speakers (as I suppose are all native speakers of their own tongue) tend to be rather sloppy in their use; you are excused for making the (relatively) reasonable but (unfortunately) incorrect assumption.  :-*
"Helsinki" Rules!
Glassboy
« Reply #6 on: December 11, 2015, 12:27:47 pm »
"Helsinki" Rules!
It would also be an incorrect assumption to assume there is one globally consistant English language.
My dialect for example contains compound words where one of the words is a loan word from another language.  In one example, the loan word is a homonym for the word for a common English food type.  Which makes any sentence containing the compound word confusing for a speaker of another dialect.
« Reply #7 on: December 11, 2015, 02:39:05 pm »
No, I did not RTFM :-[
So instead of sending a bug report the OP should send a Feature Request I guess, because an event to tell us when a tagged values has been modified would really be useful.
phdare
« Reply #8 on: December 11, 2015, 05:41:00 pm »
Sparx Team has rejected the defect  :(.
- In client project, Sparx EA element has about 200 tagged values so it seems to be not effective for getting all these tagged values to check if anything.
- I will change the Tagged Value Type to "AddinBroadcast" and develop new 'Tagged Value Note' dialog for editing them. I will handle EA_OnElementTagEdit event to update tagged value and its parent element.
Hiep
« Reply #9 on: December 11, 2015, 05:52:30 pm »
Do you mean 200 tagged values for a single element!?
That feels like much more then it was ever intended for.
phdare
« Reply #10 on: December 11, 2015, 05:59:22 pm »
Yep, 200 (maybe more) for each elements. Til now, I haven't seen any problem related to numbers of tagged values per element.
Hiep
« Reply #11 on: December 11, 2015, 06:51:12 pm »
[SNIP]
I was trying NOT to make any assumptions.  I DO know that there is NO globally consistent English.
« Last Edit: December 11, 2015, 06:51:50 pm by PaoloFCantoni »
« Reply #12 on: December 11, 2015, 07:18:09 pm »
Hiep
Wow :o
