Author Topic: Change position of messages/calls in Sequence Di  (Read 10388 times)
Ulrich
« on: November 09, 2004, 03:29:36 am »
Hi!
I have problems with editing Interaction Diagrams (Sequence Diagram). All the messages or calls that I add are always added at the end of an objects lifeline. How can I change this position? (moving up or down in the calling sequence) It is not necessary to know all interactions before starting to edit the diagram? Is it? :o
My next problem is: How can I get a lifeline for the already modelled object that I inserted? To insert and to interact with that object is not the problem, but just to show the visual presentation of the line.
Thanks Uli ;)
Re: Change position of messages/calls in Sequence
« Reply #1 on: November 09, 2004, 04:04:00 pm »
I can just click on the message/call and drag it up or down the diagram.  When I release the mouse button it has changed the sequence.
Ulrich
« Reply #2 on: November 10, 2004, 12:54:07 am »
...stupid me!
I chose the wrong diagram type. I missed that there is a special Sequence diagram and a Interaction diagram seems not to be what I wanted to do. It is a little confusing to have the objects for a sequence diagram under “Interation”.
Thank you anyway…
troutman
« Reply #3 on: November 12, 2004, 12:13:35 pm »
I am having the same problem with build 739. I can create an interaction diagram but if I try to move a message by moving it with the mouse it just snaps back to its orginal place. I can move it within its sequence in the messages but I cannot change its position.
I don't know what special sequence diagram ulrich is talking about. I need this to work on the interaction diagrams.
Thanks.
Ulrich
« Reply #4 on: November 15, 2004, 12:11:04 am »
Hi troutman!
You can choose the sequnece diagram, on the right side under behavioral, in the dialog where you choose the type of the new diagram you  want to create. (new Diagram -> Sequence) But I guest you found it already.
ciao Uli
