Author Topic: Is a Association a Method?  (Read 10423 times)
Ralph Mücke
  • I havn't done it.
« on: November 24, 2006, 06:54:08 am »
I used Rational Software Modeler and want to import a model to EA.
RSM handels Associations (simple Associations, or Aggregations, etc.) as Methods.
:o
Is this actually correct?
In opposite EA presents Associations different. Neither the Project Explorer shows Associations nor shows Associations as Methods.
Furthermore I can't see Association at all in the Project Explorer.
Where can I see Associations?
What's wrong here?
Thanks for your help.
Ralph
Best Regards Ralph
jeshaw2
Re: Is a Association a Method?
« Reply #1 on: November 24, 2006, 03:15:02 pm »
An Association is a link between two objects.  It is definitely not a method.  Therefore, one would not find it in the project browser.  Links appear as a line between the two objects in a diagram.  As normally implemented in code, and depending on the navigation directionalities, links appear as attributes in the associated objects.
I'm really surprised to hear that RSM treats associations as methods.
« Reply #2 on: November 24, 2006, 04:16:05 pm »
Most modelling tools DO show Associations in the browser (typically below methods).  They appear twice - once for each end.  That's probably what Ralph is referring to.
When you first come across to EA, it is a bit of a shock not to see them there...  EA's UI (Unique Interface) strikes again.  However, it must be said, that after a while you don't really miss them not being there too much, as other windows DO show them (Hierarchy window [Ctrl+Shift+4]).  But since you can't get at their properties through these windows, it doesn't quite give you the same functionality as the other products.
« Last Edit: November 24, 2006, 04:16:26 pm by PaoloFCantoni »
Cavan “Kevin” G. Watson
  • I love EVERYTHING including Microsoft
« Reply #3 on: November 24, 2006, 04:21:56 pm »
hello
I don't know enough about Java; but 'Getters' and 'Setters' are methods... can remember something about being good encapsulation practise, before we got C# and first class Properties. ::)
And I haven't quite worked out 21 'Owned end' options yet; if it's own then the end belongs to the class otherwise the association; presumably some kind of accessor function would be needed.
Doe's UML say anything about how you implement association in a runtime?
Or am I just rambling, it's gone midnight.
Kevin
« Reply #4 on: November 24, 2006, 05:17:31 pm »
hello
And I haven't quite worked out 2.1 'Owned end' options yet; if it's own then the end belongs to the class otherwise the association; presumably some kind of accessor function would be needed.
Kevin
Hi Kevin,
In [size=13]Property Redux[/size] I agree with you that 'Getters' and 'Setters' are just methods (my emphasis).
As to owned Ends...  If the AssociationEnd has a Role, then that End is owned by the Classifier at the other End.  (That's why the dropdown on the Roles shows the opposite End's attributes - but see: [size=13]DB relationships vs UML Associations[/size]).  If the Association has no role on that End, then the End is owned by the Association.
« Reply #5 on: November 24, 2006, 10:47:12 pm »
Hi'ya Paolo
No typo's this time ;)
I've only just got the help working here, so forgive me if I'm a bit slow.... but have just found this in the help re: Association Properties (or Connection Properties according to the help, in red to boot) for Source and Target Roles
This would seem to apply with or without a role name being provided ,or navigability ??? for that matter.
Is this where we should have the black dot (where the line connects with the classifier) ?
And I do appreciate the ability to be able to specify the member type for the role, in the case of multiplicity being greater than 1.  ;D Just as we get generic collections in C# ( and VB. Net? ).
Mmmm...
Kevin
« Reply #6 on: November 24, 2006, 11:42:21 pm »
EA doesn't (yet) support the ownership dot.   The check-box is there to support it when it comes. [Edited in the light of subsequent postings...]  My comments related to the fact that if you selected a role, then you are specifying that the End is owned.  Technically, EA should check that box automatically if you select a role.  Sparx have recently conceded that they should (and will) be synchronizing owned AssociationEnds and Attributes better.  In the meantime - they have (with build 800) added some cross-checking.  This should be included (see below).
I don't know how familiar you are with modelling tools in general, but for the most part, when a tool manufacturer says they support a particular version of a standard they usually mean "What is the absolute minimum I can do and still get away with saying I support it...".
Sparx are no worse than others and better than most...
Put in a formal change request - both for the dot and the checkbox.
« Last Edit: November 27, 2006, 02:01:31 am by PaoloFCantoni »
jeshaw2
« Reply #7 on: November 25, 2006, 04:42:50 am »
In a CIM, but also in the context of this thread, what does "ownership" mean?  What difference, to the modeler, does it make which element "owns" an association end or "owns" a role?
« Reply #8 on: November 26, 2006, 01:02:44 pm »
What are you talking about?   ???   If I check that checkbox I get the ownership dot drawn.  I have since the checkbox was introduced.
« Last Edit: November 26, 2006, 01:03:05 pm by simonm »
« Reply #9 on: November 26, 2006, 02:14:45 pm »
oops!!  Mea culpa...  I didn't have a copy of EA to check...  I should have waited...   :-[
Nevertheless, I believe my observation regarding the ownership and roles is still valid.
You can have the dot without the role, but is you have the role you must have the dot.
« Last Edit: November 27, 2006, 01:58:41 am by PaoloFCantoni »
Ralph Mücke
  • I havn't done it.
« Reply #10 on: November 27, 2006, 01:28:57 am »
MY fault  :'( associations are shown as attributes (not methods). Sorry for the confusion.
Ralph
Best Regards Ralph
« Reply #11 on: November 27, 2006, 02:17:33 pm »
Hi Jim,
I don't think the model level affects the ownership property.  As to what it means, my subsequent post should have sorted that.
