Author Topic: reverse engineering in Flash  (Read 7658 times)
jc.bihanic
« on: October 10, 2007, 12:58:13 am »
I'm trying to get a class diagram of the system I have.
The problem is, my system uses a tree structure with actionscript files contained in different folders.
EA then creates one diagram per folder, when what i need is a class diagram containing ALL the classes together.
Any suggestion?
Cheers.
JC
Re: reverse engineering in Flash
« Reply #1 on: October 10, 2007, 02:05:33 am »
None except combining them manually (or via automation) in a single diagram.
jc.bihanic
« Reply #2 on: October 10, 2007, 04:33:14 am »
Thanks for your answer.
I'm new to EA.
Is there some tutorial somewhere on how to do use automation for that matter?
« Reply #3 on: October 10, 2007, 05:46:50 am »
Hm. I'm now so much saddled that I can work with few documentation. In the help you will find quite a bit. Also some examples are provided with the EA installation (see the program folder). There is a separate ressource in beta which can be downloaded but I can't recall where. Either you search the forum or you wait for someone else to post the location.
« Reply #4 on: October 10, 2007, 07:05:03 am »
...There is a separate ressource [sic] in beta which can be downloaded but I can't recall where. Either you search the forum or you wait for someone else to post the location.
The resource Thomas refers to is the EA SDK. A few builds ago this was merged into the EA help file and users guide. If you are using a very recent build of EA you have these now. Otherwise you can download the current build of either documentation item.
« Reply #5 on: October 10, 2007, 09:04:53 am »
resource
Ressource = german writing
« Reply #6 on: October 10, 2007, 11:33:49 am »
Were it not for the spell checker in Firefox you wouldn't be able to read anything I wrote Thomas.   :-X
[EDIT: Note the correction in bold - Firefox won't prevent me from making that kind of blunder.]
« Last Edit: October 11, 2007, 02:15:46 am by Midnight »
« Reply #7 on: October 10, 2007, 10:21:46 pm »
Gotcha! I work with Safari - and no spell checker. That's why I make so many mistakes ;)
revdev
  • Love this stuff.
« Reply #8 on: October 22, 2007, 09:25:14 am »
For the purpose of creating a class diagram, copy all your source files into a single folder, then do the import.
revdev
re-Vision Development
