Author Topic: HTML report and attached file  (Read 6565 times)
glads
« on: June 29, 2005, 12:22:31 pm »
Hi everyone,
I have a problem when generating html reports when my use cases have attached files.
The problem is that I can't use relative paths, because when html is generated, the html locations are different and the file links are lost. With absolute paths, things are much worse!!!  :-[
I use to attach storyboards files with use cases. That's why I need them.
Thank you,
Gladstone.
Re: HTML report and attached file
« Reply #1 on: June 30, 2005, 04:16:42 am »
I guess this is a general problem. You could use a sed-command to post-process the paths.
glads
« Reply #2 on: July 01, 2005, 03:19:08 pm »
I can't see how I could use a sed-command, since the html code is generated by EA...
Is there some way of describing path variables?
Gladstone.
« Reply #3 on: July 04, 2005, 02:07:55 am »
I meant by using a post-processor.
glads
« Reply #4 on: July 04, 2005, 01:56:26 pm »
A external tool for changing the html generated by EA, is it?
« Reply #5 on: July 05, 2005, 02:45:25 am »
Yes. sed is an inline editor (in UNIX) that is used to change strings in an ASCII file. If you have a pattern in your path (which is very likely) you can change it easily. Under Windows you could use a simple Perl script to achieve that.
