Author Topic: import and synchronize a  Rose imported model  (Read 3995 times)
Rsacristan
« on: July 12, 2005, 01:28:57 am »
I'm working with a model imported from Rational Rose.
Everything is fine, but I need to synchronize the model (the classes from the logical view) in EA with the source code (in Delphi).
I tried to syncronize some classes I imported directly (inverse engineer) from the code to EA and It works fine. But when I try to do the same with the classes imported from Rational Rose, it doesn't do anything.
Can anybody tell me how could I link the imported classes from Rose with its corresponding source code so I can syncronize them?
Thank you.
Re: import and synchronize a  Rose imported m
« Reply #1 on: July 12, 2005, 04:42:20 am »
You need to check the file name where the class is stored. Open the properties window (best: dock it somewhere) and inspect Filename. I guess this is not filled when importing Rose XMI.
Rsacristan
« Reply #2 on: July 12, 2005, 05:25:34 am »
I've tried that already, but doesn't work.
The classes I try to sincronize are included in a .pas (Delphi unit)  with some other classes, not alone. I don't know if that can be the problem.
« Reply #3 on: July 12, 2005, 05:33:31 am »
Check also that the programming language is set correctly.
